My newly refined criteria - Page 2 - SailNet Community
post #11 of 17 Old 01-03-2008
MikeAlyea,
Your specifications sound good. I would add several other things that I like, but I'm sure others will disagree. First, I like skeg mounted rudders. It offers rudder protection without a full keel. Second, I would find a boat with an intergal keel. No keel bolts and hull/keel joint to worry about. Last and not least, I would place an autopilot on the must have list since you sail singlehanded alot. Buy the best you can afford.
Best of luck
PaulM
PaulM1 is offline
post #12 of 17 Old 01-03-2008
blue collar cruiser
soulesailor's Avatar
One thing I'll add to the pot is a nice suit of sails. A lot of work and modification on a boat can be done by yourself somewhat inexpensively. A really nice boat with older sails could end up being more expensive than a boat that needs some cosmetic work but has better sails. Good luck with the hunt.
who is staring at the sea is already sailing a little
soulesailor is offline
post #13 of 17 Old 01-03-2008
On the hard
CharlieCobra's Avatar
Ok, I have a keel stepped mast and this is the first one I've seen that doesn't leak. What's wrong with a mizzen? I have one and love the options it gives me.
CharlieCobra is offline
post #14 of 17 Old 01-03-2008
Cruiser/Lats and Atts TV
Moonfish's Avatar
Mike - Maybe I missed it, but do you have a price range?
"Always approach the dock at the speed you wish to hit it."
s/v VENUS
1978 North Sea 33 Pilothouse Cutter (Ta Chiao)
Moonfish is offline
post #15 of 17 Old 01-03-2008
Believe it is $50-60,000 from his other thread.
sailingdog is offline
post #16 of 17 Old 01-04-2008 Thread Starter
Yes, $50,000 to $60,000 is the max range, but of course, I'd be happy to pay less if the right boat was available for less.
MikeAlyea is offline
post #17 of 17 Old 01-04-2008
Mike,
Agree with the others on the keel stepped mast criteria. referring to your other post, MKII at least are deck stepped. Not sure about the MKI. However, if the design is correct, and Catalina's have not had problems, a deck stepped mast should not be an issue.
tommyt is offline
possible to dry newly wet decks? njabro Gear & Maintenance 2 04-12-2004 08:21 AM
Criteria for Successful Cruising Liza Copeland Cruising Articles 0 08-27-2003 08:00 PM
Criteria for Successful Cruising Liza Copeland Her Sailnet Articles 0 08-27-2003 08:00 PM
