"Oil analysis from a diesel crankcase is meaningless in and of itself. Unless it is routinely done such that one can observe a trend over time, the analysis cannot be interpreted properly. Anyone who suggests a decision be premised on a sinlge analysis is simply misleading you"
Agreed. It has to be done properly. warm the motor, take the sample. A trend would be nice, but not possible on a survey situation.
Its worthless if the oil has just been changed. (had a shop take a sample of two 454's on a go-fast... the monkeys changed the oil and filters THEN did the sample, bless their hearts)
If however its between changed, you can see quite a bit.
Fuel dilution, ash, sodium, carbon.....(all fuel related) copper, tin, lead, chromium... (all bearing related)
for the 20-30.00 it costs, if the motor DOES NOT have fresh oil in it, Its worth it. Heres a sample of whats tested.
Elemental Metals (24) by ICP
Water % by Crackle or FTIR
Viscosity @ 100C (ASTM D445)
Fuel Dilution % by FTIR
Soot % by FTIR
heres a link...
http://www.polarislabs1.com/test-exp...ear-metals.htm
