Old 02-01-2008
asivesind's Avatar
abandon shore
asivesind is on a distinguished road
Newport 28 vs. Catalina 27
I have found a newport 28 and a catalina 27 that are both in excellent condition, and both priced around $9,ooo. It is a bit of a hard choice. I single hand most of the time, and would be sailing in the S.F. bay. The newport has an A-4 and the catalina has a diesel. The newport is 79 and I think the catalina is about the same age. Any thought's would be great. Thanks you. T
Old 02-01-2008
blt2ski's Avatar
If you want to give PHRF ratings any credence, the Newport is about 10 sec a mile faster than the Cat. IIRC the newport was a C&C design, and possibly built by for Newport, but do not quote me on the latter!
I believe the newport is a bit bigger overall, with a nicer interior.
Either if properly rigged, should be easy to single hand. Personally with this in mind, if one or the other has a cockpit main traveler, that would be my first choice, or remove the cabin mounted one, and install one in the cockpit. I believe newport may be this way, Cats are more know for cabin top main travelers for the majority of the ones I have seen.
Either would be a good boat.
marty
She drives me boat,
I drives me dinghy!
Old 02-01-2008
gonesailin40 is on a distinguished road
I prefer diesel over gasoline engines. I find them easier to troubleshoot and easier to repair when needed. I also feel they last longer than gasoline engines.
As far as which boat would be better. I am sure you can find many people to make an argument for either boat. If it would be possible to take each one out for a sail you might have a better chance deciding on which one.
I would think that at 9k, both in "excellent condition" it would hard to go wrong either way.
Old 02-01-2008
GySgt's Avatar
Semper Gumby
GySgt is on a distinguished road
Send a message via MSN to GySgt
I would second gonesailin40 advice and take them out for a sail. The Cat 27 I sailed in the bay recently had a lot of weather helm.
I like pigs. Dogs look up to us. Cats look down on us. Pigs treat us as equals.
Sir Winston Churchill
Old 02-01-2008
Moonfish's Avatar
Cruiser/Lats and Atts TV
Moonfish is on a distinguished road
Yes, the Newport 28 has a C&C designed hull. The rest of the boat was Capital Yachts. My first boat was an '84 N28 MkII, and it was quite a nice little performer for a boat that had decent cruising comfort in 28 feet. Loved that boat, and at times still miss her. The only reason I see in your choices not to choose the Newport is the A4. I'd always prefer a diesel, but then again there are a ton of old boats still out there puttering around on rebuilt A4s. And I would guess you'd find a pretty good source of knowledge on A4s in the Gear and Maintenance forum. I haven't looked, but there's probably an Atomic 4 email list as well.
"Always approach the dock at the speed you wish to hit it."
s/v VENUS
1978 North Sea 33 Pilothouse Cutter (Ta Chiao)
Old 02-01-2008
Valiente's Avatar
I've sailed on a Newport 27 and a C&C 27, and I prefer the Newport. If the Atomic 4 is fresh water cooled, I would opt for that...it is a more appropriate small sailboat engine than a diesel in the sense that it is low compression and doesn't mind getting started cold and then shut off 10 minutes later...a small diesel sees wear and tear from short run times.
The Newport 28 is probably about the same weight over a somewhat larger hull and is a slightly tender but speedy boat. The C&C at 7,500 lbs. can keep sail up longer and can bash into waves that might slow or stop the Newport.
My understanding is that SF Bay can get quite lumpy, but I don't know how race-oriented you are.
Old 02-01-2008
asivesind's Avatar
abandon shore
I am not to interested in racing... at least for now. Thanks for the info on the diesel. I would imagine it would only be used in short spurts, just enough to get me into open water. I think I just need to go sailing, fine time of year to sail the bay!!
Old 02-02-2008
Valiente's Avatar
Then the Atomic 4, converted to fresh water cooling (not difficult) is probably a more durable choice, assuming it's in reasonable shape. They are easy engines on which to work.
Old 02-02-2008
Plumper's Avatar
Sailor
Plumper is on a distinguished road
In our club there is a Newport 28 that wins all the races when the winds are lighter than 12 knots. The kicker is that the owner claims the boat is not very well built. He says that when he hauls on the backstay the door forward won't open. He recognizes the short comings and loves the boat. There are also a couple Catalina 27's. They are a little slower but a little (not much) more robustly built. The big difference is their huge sliding hatch cover. It makes the companionway big enough for two people. Comfy but structurally a bit of a compromise. I would be happy with either boat for weekending and beer cans.
Gaz
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Old 02-02-2008
BarryL's Avatar
BarryL is on a distinguished road
Hello,
My first boat was a Catlina 22, my second a Newport 28 (and my third and current is an O'day 35). For my second boat I was looking for something in the 28-32' range, preferably a Catalina 30. I looked at the Catalina 27 and it was just a little too small for me. The newport, even though just a little bigger, was big enough.
Anyway, IMHO, the Newport is nicer than the Catalina. The newport should come with self tailing winches, lines led aft, etc. The interior is also nicer. It should have a teak and holly sole compared to bare fiberglass, padded head liner compared to bare fiberglass, hot and cold pressure water, A/C and D/C electrical system, etc.
The Catalina 27 is a nice boat, but, IMHO, the Newport 28 is a nicer boat and is more a 'big boat' than the Catalina.
Good luck to you,
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Catalina 309 & the Catalina Association Siamese General Discussion (sailing related) 4 07-24-2007 09:22 PM
Crusing -Catalina or Newport? xavier6162 General Discussion (sailing related) 12 03-03-2002 07:48 AM
Crusing -Catalina or Newport xavier6162 Cruising & Liveaboard Forum 2 02-22-2002 07:59 AM
The Catalina 310 Micca Hutchins Buying a Boat Articles 0 10-07-1999 08:00 PM
The Catalina 310 Micca Hutchins Racing Articles 0 10-07-1999 08:00 PM
