You found the boat you want... - Page 3 - SailNet Community
post #21 of 30 Old 02-11-2008
Senior Moment
SailorMitch's Avatar
Something less. I made a big deal out of the blisters and some of the other items the surveyor found (none of them deal killers) and worked the seller over pretty well. I bought the boat for considerably less than the value the surveyor placed on it in his report (he seller never saw that section of the report of course!) I never thought about deducting the price of a full peel, etc. because everyone involved in the deal knew that wasn't necessary. But it's all in what you're comfortable with.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
SailorMitch is offline
post #22 of 30 Old 02-11-2008
Best Looking MALE Mod
Cruisingdad's Avatar
Originally Posted by midlifesailor View Post
Solid laminate, '91 Catalina.
If I were to go forward, I'd either try to buy the previous survey and spend a couple of hours going over it, or start again from scratch.
The fellow that did the previous survey was favorably mentioned here on sailnet in a couple of the surveyor recommendation threads, so I feel he'd be trustworthy and knowledgeable.
What model Catalina? Who was the surveyor? The blisters will probably be find, just grind out, etc. That should be negotiated in the price. I am not aware of any blister problems with 1990+ Cats, but give me the model and I will see if anyone else knows.
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #23 of 30 Old 02-11-2008 Thread Starter
CD check your PM's.
Thanks.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
PalmettoSailor is offline
post #24 of 30 Old 02-11-2008
chucklesR's Avatar
Midlife,
Buddy of mine bought a 1986 Catalina 30 in 2005 with literally hundreds of blisters on it. We (he and I) spent 3 weekends grinding, filling and fairing, then barrier coated and bottom painted. We did not strip all gell coat, we spot repaired each one, merging several when needed and used a long stip of flexible wood as a fairing batten.
Total cost - 600 - 700 bucks and 3 weekends of going home covered in blue dust. I already had two angle grinders and large sanders - blew my shopvac to hell so my buddy replaced it. I did some gelcoat fixes during that time period while he was pasting in epoxy (no dust periods).
The original asking price was 24k, he paid 16k. The owner was 70+ and needed to dump the boat, it had not left the pier in 3 years.
chucklesR is offline
post #25 of 30 Old 02-12-2008
I had to smile while reading this...
Ok, buddy, quit hyperventilating about less than a dozen half dollar size blisters willya? I highly doubt that they're serious, and even if they've burned a caustic ooze filled hole in the hull, they can be ground out. It doesn't mean you're going to need a haz-mat suit and a team of fiberglass geeks at hundreds per hour.
The boat is 17 yrs old. its going to have a few blisters. Unless they've gone off the deep end, peeled, barrier'ed and epoxied. I doubt that they have and I doubt that it was/is needed.
I can't warrant anything about this particular tub, but suffice it to say it'd be a rare bird if this caused a real big problem.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
cardiacpaul is offline
post #26 of 30 Old 02-12-2008
Handsome devil
Stillraining's Avatar
Ditto
Card's post...If I were the seller and you asked for a peel job for 10 blisters Id tell you to take a hike...Figure up for a reasonable amount to cover grind and fill at the yards price and offer that or walk... Thats what I did.
Stillraining is offline
post #27 of 30 Old 02-12-2008
supergrade's Avatar
I agree with the consensus here.....blisters are really no big deal 90% of the time. If, as you said, there are only a handful of small ones, then let your offer reflect that and go for it. When you get a good feeling about a boat, a few blisters shouldn't be an obstacle (IMHO).
1977 Bristol 29.9
"Aut viam inveniam aut faciam."
supergrade is offline
post #28 of 30 Old 02-12-2008 Thread Starter
Well as it turns out, I was able to learn the problem was more extensive than I was initally informed (suprise). There were a much greater number of blisters with several large ones on both sides of the hull and more small ones than you could count. It was made clear that a bottom peel was in the near future or this boats value would be severely impacted.
I'm taking a pass, at least for now. At this point I'm not sure if I'm willing to take the risk and deal with the inconvinience at any price. I may change my mind and make a steeply discounted offer, but there is always another boat and I think I'll save a lot of discontent by waiting till it comes along.
The search goes on.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
post #29 of 30 Old 02-12-2008
A-HA!!!
ok, wow, she must have gone awhile without having maint. done. pass.
post #30 of 30 Old 02-13-2008 Thread Starter
A-HA!!!
Yeah, it seems like the entire maintenence budget was spent above the waterline. I think if your plan is to leave your boat in the water for years at a time, you should start with a stripdown to gel coat and carefully put on a barrier coat then fresh bottom paint. This boat had no barrier coat at all. I know barrier coats are not the be-all-and-end-all, but I can't help but think it may have really changed the outcome for this boat.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
Name Change for Older Yacht ChiefOren Boat Review and Purchase Forum 12 10-08-2007 10:59 PM
Trailering? Pick a Boat Bruce Caldwell Cruising Articles 0 07-22-2004 08:00 PM
Understanding the Racing Rules, Part Three Dean Brenner Racing Articles 0 09-09-2002 08:00 PM
The New Racing Rules Dobbs Davis Racing Articles 0 04-04-2001 08:00 PM
The Balance of Hull and Sails Steve Colgate Buying a Boat Articles 0 05-25-2000 08:00 PM
