Pre 1990's boat purchse considerations - Page 2 - SailNet Community
post #11 of 45 Old 02-14-2008 Thread Starter
Best Looking MALE Mod
Cruisingdad's Avatar
If you have tinned wire on that boat, it was replaced for you, in my opinion. As far as the soldering and automotive connectors... well, the previous owner lived in Michigan?? What can I say??? (smile).
I am however, quite certain that the connectors came off of a F350 and not a Corvette!!
HEHE!
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #12 of 45 Old 02-14-2008
teshannon's Avatar
I am not sure the costs we have incurred will really represent doing it. THat is because wire is absolutely out of sight right now ($$$$$$$$) due to gold. However, I estimate, assuming our time is free, that we have dropped about $1,000 in the mast. That includes a new deck/steaming light, and some new lighting on the head. You may say, "Well, I am not replacinag those lights, etc...)," but upon closer inspection, you will likely find them corroded due to poor wiring, and why do a half-A** job when most of the expense is the wire???
- CD
Fortunately for me the PO had the mast rewired and new lights installed just before I bought the boat. If I remember right from the receipts the $1k is about right.
teshannon is offline
post #13 of 45 Old 02-14-2008
teshannon's Avatar
HEHE!
- CD
Cd,
Have not found any solder connections or automotive connectors thank god. Not really sure if I have tinned wires or not but will check. Any obvious way to tell? I'll put a question on the TOG site and see what responses I get. thanks again.
post #14 of 45 Old 02-14-2008
If the wire is copper colored, green or black, it isn't tinned... tinned wire is generally tin (Silver) in color.
sailingdog is offline
post #15 of 45 Old 02-14-2008
poopdeckpappy's Avatar
most of the wiring was copper, and not tinned (as is dictated by ABYC). I also would assume that you will find a LOT of poorly insulated wiring and likely a lot of soldering. That was popular during the day.
ALmost without exception, we have been forced to pull all the wire nd replace with tinned wire. Almost without exception, the solder joints have corroded and cracked and have either failed or are close to failing.
I have the same issue with my 37, knew that going in
The very deep bilge in the Tayana (and other boats for that matter) will have built up a considerable slime and who knows what sits down in there. Because the bilge is so deep, many of the V-42 owners have put the switch on the stringer about 2 feet below the footboards. I have a fix for that, for anyone that is interested. You may PM me.
I would be interested, what I found on mine was a piece of wood, glassed/epoxied to a flat lava stone at the bottom of my bilge, to this was fastened the float switch.
When the pump finally gave up the ghost, I replaced the whole setup ( PAR belt pump and float switch ) with a Rule 750 auto pump, but utilized the the flat lave stone, the bilge never has more than 2" of water in it.
However, I would be interested in any improvements that you would suggest
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #16 of 45 Old 02-14-2008
Moderator
Jeff_H's Avatar
My problem with the 58 is that its still an old IOR hull form. The Tayana that I think may turn out to be one heck of a neat boat is the new 54. Now there's a nice piece of naval architecture.
Jeff_H is online now
post #17 of 45 Old 02-14-2008
teshannon's Avatar
SD,
Thanks. everything on my boat is copper colored. Whew!
post #18 of 45 Old 02-14-2008
I'd rather be sailing
labatt's Avatar
The 58 is the 55 with an extended sugar scoop transom - that's the only difference. The 54 is the new Dixon designed Tayana.
CD - one of the other things you will find about 1980's Taiwanese boats is that some of the hardware will be custom fabricated by the yard in order to save money, and may not have been fabricated using high quality stainless or in a high quality fashion.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
labatt is offline
post #19 of 45 Old 02-14-2008
Originally Posted by teshannon View Post
SD,
That's not a " whew ", it's an " oh damn " I need to rewire
1974 Ranger 33
post #20 of 45 Old 02-14-2008
teshannon's Avatar
[QUOTE=poopdeckpappy;265606]That's not a " whew ", it's an " oh damn " I need to rewire[/QU
Now I'm thinking I don't know for sure what I have but will be on the boat tomorrow and will check. I'll report back.
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 2 09-12-2012 03:54 PM
Making Passage w/o a Rudder wind_magic Seamanship & Navigation 60 07-16-2010 01:23 PM
The Search for the First Boat - long learning curves pmoyer Boat Review and Purchase Forum 45 12-20-2008 01:28 AM
Construction of a PVC (Divinycell) cored boat Giulietta Sailboat Design and Construction 8 10-19-2007 05:46 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 07:00 PM
