Pre 1990's boat purchse considerations - Page 3 - SailNet Community
post #21 of 45 Old 02-14-2008
Teshannon-
If it is all copper colored... that is bad... silver-colored stranded wiring is very good... solid silver-colored wiring, fastened with wire nuts is probably aluminum wiring and a really, really bad idea.
sailingdog is offline
post #22 of 45 Old 02-14-2008
teshannon's Avatar
Teshannon-
SD,
Really slow on the pick up today. The more I think about it I don't remember seeing copper colored wire behind the control panel but I will have a close look tomorrow. For some reason I'm remembering copper somewhere but not a lot of it.
teshannon is offline
post #23 of 45 Old 02-14-2008 Thread Starter
Best Looking MALE Mod
Cruisingdad's Avatar
Originally Posted by poopdeckpappy View Post
That's not a " whew ", it's an " oh damn " I need to rewire
HEHEHEHEEHAHAHAHAHAHEHEHEHEHEHEH!!!!!!!
My kids came in here wondering what I was laughing about so hard...
T- if you boat has not been reqwired by a PO, you should have copper. I would not run out to the marine store and stock up on 5k in wire, but put it on the list to start replacing as you can. If you drop your stick, that is a GREAT time to pull that wire.
- CD
PS I would question whether you relaly have to rip it all out... that may be a good questions for the board. I will post another thread and get opinions.
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #24 of 45 Old 02-14-2008
chucklesR's Avatar
On the other hand, that non-tinned automotive spade type connectered incorrectly run undersized aluminum wire on that 1980 something classic plastic next door to your boat is PROBABLY not going to erupt like Mt Saint Helen tomorrow at 3am and burn every boat in the marina to the water line.
After all, it hasn't yet.
per BoatUS IIRC electrical problems are the number 1 cause of boat fires.
chucklesR is offline
post #25 of 45 Old 02-14-2008
purveyor of mischief
sanctuarysam's Avatar
VOTED BEST LOOKING AND SMARTEST SAILNETTER..
uhm, when was the election..i never even got a proxy ballot in the mail.
i want a recount,i'm thinking hanging chads here....
By three methods we may learn wisdom: first, by reflection, which is noblest,second is by imitation, which is easiest,third is by experience, which is the bitterest.
Sam
Sanctuary, Sabre 30 mkIII
sanctuarysam is offline
post #26 of 45 Old 02-14-2008
moderate?
camaraderie's Avatar
Sure..tinned wire is better...but there are a few hundred thousand older boats out there doing just fine with plain old copper. As recently as year 2000 some VERY high end boats were offering tinned wire as an OPTION at purchase. So it is really just a better way of doing things. Replace it as you need to with tinned and get rid of any solder joints. CD...funny...I did not have a single solder joint that I can recall on my boat. My guess is the PO of your Dad's did some work.
Labatt...I think that there is a tendancy for Taiwanese boats to get painted with a broad brush. What parts were not well made on you Passport? I did not in the course of my refit or subsequent use find one substandard quality fitting on my Tayana. Now I know that decks and tanks are issues that need to be checked or dealt with on Tayanas, but your statement sounds like ALL Taiwanese boats used cheap fittings to save $$. Lets keep generalized negative comments to a minimum and try to be specific about any negative stuff. Kinda like saying Valiants have known blister problems when the issue is specific to a production run.
camaraderie is offline
post #27 of 45 Old 02-14-2008
teshannon's Avatar
CD,
Fortunately the PO had the mast rewired and lights replaced just before I bought her.
- CD
post #28 of 45 Old 02-15-2008
teshannon's Avatar
Well put Cam, I have had not one problem with my Tayana related to quality of fittings. in fact, overall I'm very impressed with the quality of the hardware on the boat, first class all around.
post #29 of 45 Old 02-15-2008
poopdeckpappy's Avatar
I gotta agree, I'm very pleased with the original workmanship, my problem is, either the original owner or the PO went from bad to worse, but like I said, it was a given when I bought the boat that the wiring was going to be less than good
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #30 of 45 Old 02-15-2008
teshannon's Avatar
Ok, so I'm at my boat, an 87' Tayana and have looked at the wiring. All of the original wiring is copper with crimp connectors. Well insulated and no solder connections. Any later wiring is tinned stranded wire, again all well insulated with crimp connections and no solder joints. As I mentioned before all of the mast wiring has recently been replaced. Everything looks to be in great shape, I've had no problems, and so I plan to do nothing.
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 2 09-12-2012 04:54 PM
Making Passage w/o a Rudder wind_magic Seamanship & Navigation 60 07-16-2010 02:23 PM
The Search for the First Boat - long learning curves pmoyer Boat Review and Purchase Forum 45 12-20-2008 02:28 AM
Construction of a PVC (Divinycell) cored boat Giulietta Sailboat Design and Construction 8 10-19-2007 06:46 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 08:00 PM
