Pre 1990's boat purchse considerations - Page 5 - SailNet Community
post #41 of 45 Old 02-15-2008
teshannon's Avatar
CD,
Interesting. I did post a question on the TOG site and the few replies I got said no problems.
teshannon is offline
post #42 of 45 Old 02-15-2008 Thread Starter
Best Looking MALE Mod
Cruisingdad's Avatar
The connections into the steaming light and deck lights were corroded. These would be copper wiring in the elements, obviously.
Do you mena they have no problems because they are still working, or they have no problems because they have looked at them and there is no corrosion or issues? The lights worked during the survey... but in the two weeks down there we had increasing problems.
Big difference.
- CD
CAM -
Have you had any corrosion issues with your wiring? WHat did you do on your T52? Same years as dad's. WHat about other owners?
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #43 of 45 Old 02-15-2008
teshannon's Avatar
CD,
No one really elaborated and there were only a few responses so far.
post #44 of 45 Old 02-15-2008
moderate?
camaraderie's Avatar
CD...I think one will always have problems with the connections on deck lighting depending on how much time they spend in salt water and how well you can seal them. Most of my problems occur within the lights at the contact points between bulb and socket...but occasionally you have to clean up the wiring as well. A bit of emery paper and 5 minutes does the trick.
As I said...other than at contact points in exposed areas...I've had ZERO issues with my all copper wiring and in working with it to add in new items, it is evident that it has many more years of life ahead.
camaraderie is offline
post #45 of 45 Old 02-15-2008
teshannon's Avatar
I did have a port running light connection corrode but consider that just normal maintenance.
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 2 09-12-2012 03:54 PM
Making Passage w/o a Rudder wind_magic Seamanship & Navigation 60 07-16-2010 01:23 PM
The Search for the First Boat - long learning curves pmoyer Boat Review and Purchase Forum 45 12-20-2008 01:28 AM
Construction of a PVC (Divinycell) cored boat Giulietta Sailboat Design and Construction 8 10-19-2007 05:46 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 07:00 PM
