Catalina 30 - Page 2 - SailNet Community
post #11 of 12 Old 02-19-2008
If you have the "smile" you will have corrosion on the keel bolts. I saw a picture of a piece of 309 stailness cut in two by a rubber band . Oxygen, in this case, prevents corrosion because the oxide coating prevents more damage to the steel. When the steel is enclosed inside the fiberglass, and a crack allows sea water to get in, corrosion takes place in an oxygen free environment. Like under the rubber on the band. I was astonished at this, but this comes from a powerplant maintenance periodical. You will have to face this eventually if your Cat has the smile.
"Ulysses" - Alfred Tennyson
TomandKarens34 is offline
post #12 of 12 Old 02-19-2008
moderate?
camaraderie's Avatar
Just an aside and a bit off topic but we had a raging argument over the Caliber encapsulated keel and how ALL such keels were susceptible to water intrusion in a hard bump or grounding. Now might be a good time to remind the group that we seem to have far more ACTUAL problems reported with bolt on keels. Is that because there are far more of them? Dunno. But it must be noted that NO keel type is without problems.
camaraderie is offline
MacGregor 22 vs. Catalina 22 lastmate Boat Review and Purchase Forum 22 11-13-2012 05:12 PM
Catalina 270? jbarros Boat Review and Purchase Forum 11 07-27-2008 04:41 PM
Catalina 309 & the Catalina Association Siamese General Discussion (sailing related) 4 07-24-2007 10:22 PM
The Catalina 310 Micca Hutchins Buying a Boat Articles 0 10-07-1999 09:00 PM
The Catalina 310 Micca Hutchins Racing Articles 0 10-07-1999 09:00 PM
