  #11
Old 02-25-2008
camaraderie's Avatar
moderate?
Paul...you mean like one of these??
BTW...Paul...aren't the Freedoms TOTALLY cored in the hull? Any concerns you have seen with that?
  #12
Old 02-26-2008
cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough
the winch buddy is good, I've tried one on the catalina 27, but needs more juice for a bigger boat than that can provide.
I believe all freedoms are balsa, and ....
nope.
if its good enough for Mr. Pearson, Mr. Hoyt, Mr. Mull, (not the designer of the 40) Alerion & TPI (makers of those terribly built ~sarcasm~ j/boats) I'm not going to argue with 'em.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
  #13
Old 02-26-2008
christyleigh's Avatar
christyleigh is on a distinguished road
But would I be wrong in assuming that you are speaking of a small single speed winch on that c27? Just thinking that a larger 2 speed would make a big difference when trying to raise with a winch buddy? Of course there is always the option of a new $$$$ power winch but I was just wondering about the possible undersizing of some of the earlier winches.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
  #14
Old 02-26-2008
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Originally Posted by jlodolce View Post
Tell me more about why you think the huge mainsail would keep a sailor at the dock?
Don't have any direct experience with handling that main, just conveying what I heard from others. It does seem to be a factor in his reluctance to go out - since the guy I referred to is a solo-sailor.
I suppose as others have said, a power winch or a strong back are prerequisites, coupled with a Doyle stackpack, or at least lazy jacks for dousing the main.
True Blue . . .
sold the Nauticat
  #15
Old 02-26-2008
"But would I be wrong in assuming that you are speaking of a small single speed winch on that c27? Just thinking that a larger 2 speed would make a big difference when trying to raise with a winch buddy? Of course there is always the option of a new $$$$ power winch but I was just wondering about the possible undersizing of some of the earlier winches."
Yes, actually, barient 22's 2 speeds. (and 16's,) had a total of 7 winches on that boat, a couple of long handles too.
gotta remember, i'm a cripple... cute, but crippled.
  #16
Old 02-26-2008
fynbo is on a distinguished road
It should be a great boat for what you want.
As a Freedom owner I can tell you that you should worry much more about getting the sail down and adding reef-points than about getting the sail up.
On the way up you are usually in control, so that is generally trouble-free or at most work.
Taking it down or reefing on the other hand can be a problem. If the boom is out too far, or you are not close to the eye of the wind when dropping the sail, the sail will not come down, and when a fully battened sail that big starts flogging you don't want to have to come near it.
The factory reef-points are for "sailing" not for being abused by a storm. I have not been on a 40/40 but you have to have a way of carrying less but efficient sail. The mast adds windage and you will need some kind or storm sail that has a good foil shape if you get caught in a NE. My guess is the jib or stock main reefed will be too much power.
You probably also need additional sail slides of the top of the main sail. Gusts can peel a full roach main like the Freedom right off the mast with plastic slides and with metal slides it could kink the sail track, making it harder to get the sail down. You are not likely to be "saved" by the sails blowing-out either, so you have to have an exit plan.
When Tillotson-Pearson sold off Freedom Yachts they licensed the construction technology as well, so it should be an excellent boat. The above are concerns for any boat with a fully battened large main.
  #17
Old 02-26-2008
Jim Lo Dolce
jlodolce is on a distinguished road
Freedom 40
Sab30. I would be happy to read a long email from you. You can send it to me at jlodolce@dreamscape. The system wouldn't let me send you a personal message thru their system since I do not have enough postings. Feel free to email me directly.
Guess what, the system won't let me post my full email address without 10 postings either.
  #18
Old 02-26-2008
Jim Lo Dolce
True Blue: It does have a good electric winch. Thanks for the heads up regarding the large main.
  #19
Old 02-26-2008
Jim Lo Dolce
Fynbo: thanks for the posting. It is helpful.
  #20
Old 03-26-2008
invictus
Sorcerer33x is on a distinguished road
Freedom 40/40
I'm looking at Freedom 40/40s - I'm told running backstays are good for heavy weather because the carbon fiber mast is pretty springy under certain conditions. Where are you in the process -- will you buy one?
You may post attachments
You may edit your posts
Freedom 40/40 sab30 Boat Review and Purchase Forum 3 02-10-2008 10:27 PM
Freedom 35/36/38 vs Pearson 36-2/38 eherlihy Boat Review and Purchase Forum 9 01-08-2008 08:41 PM
Financial Freedom Afloat Kathy Barron Gear and Maintenance Articles 0 09-30-2000 08:00 PM
Financial Freedom Afloat Kathy Barron Cruising Articles 0 09-30-2000 08:00 PM
SEO by vBSEO 3.6.1
