03-16-2008
Originally Posted by DoomDahDoomDoom
As a first-time buyer, I'm trying to edumacate myself on things to look for when I inspect a used boat.
Just looked at one yesterday (late 70s boat) whose stantions were very loose. The decks all felt solid, and otherwise the boat seemed in very good shape for it's age (there was some "waviness" in the gelcoat, but it didn't seem a problem to my untrained eyes) . Just wondering if I'd need to be replacing those stations, or if there is a simple fix... OR is this a terrible sign of some unseen problems??
The decks of many production sailboats are a laminate of fiberglass with a core of some sort, most often balsa, but sometimes plywood and rarely some other product. Anywhere something penetrates the deck (all over the place on a sailboat) it creates a potential path for water to enter the core. Then several things happen none of them good, like freeze thaw causing separation of the core from the balsa (delamination) and rot of the core causing, soft, spongy areas in the deck.
Loose stantions may just be loose or they may have let water in doing signficant problems that are expensive to have fixed. Clues like signs of leakage around chainplates and stantions below decks provide clues but the only way to know how extensive these types of problems are is to have an experienced surveyor evaluate the boat for you.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
