03-20-2008
Harpoon-
It would help if you said what kind of boat it is. If the boat has a solid fiberglass deck and no interior overhead added, then condensation might be a very common issue. The interior of the boat would heat up in the sun, increasing its ability to hold moisture, and then at night, it would cool off, and the excess water would condense out.
Generally, more information when asking a question is going to get you better answers. BTW, ceilings on boats are the interior vertical surfaces that line the hull...not what is overhead, which is generally called an overhead on a boat.
I'd also recommend you read this post to get the most out of your time on sailnet. Welcome to sailnet.
