What do YOU look for - Page 3 - SailNet Community
post #21 of 42 Old 03-27-2008
Señor Member
TrueBlue's Avatar
No more than ONE hull.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #22 of 42 Old 03-27-2008 Thread Starter
Learning the HARD way...
eherlihy's Avatar
Smile Great stuff!
I'd also check the condition of the interior of the lockers and such. Often, the outer areas are "cleaned up" for sale, but the nooks and crannies will tell you what the real condition of the boat normally was.
'Dog - that is a GREAT suggestion! And, if The Admiral is impressed, will hire a surveyor for round 2.
Val - yes, a leaky deck is a red flag (meaning "stop") to me too, but I have only talked to the broker once about this, and we all know about brokers... Specificaly, I plan to inspect around the stancions on the deck, looking for crazing around them, step around them, to tap around with a plastic hammer, and then (even though it's on stands) to jump on the deck looking for flex. Also I am very familliar with the sailing characteristics of, and room on this model Pearson.
Ahab - The magnum is a yet-to-be classic. Too bad that Chrysler stopped producing them this year. If you are into car collecting, I'd advise taking good care of it.
Tejas - great book reccomendations, but inspection is set for this weekend. I can't read that fast.
TB - you're just lookin for trouble from 'Dog, aren't you... IIRC, 0 < 1 yes?
Thanks to all!
-Ed
eherlihy is offline
post #23 of 42 Old 03-27-2008
Maine Sail's Avatar
The bast advice I can give is that you NEED to buy your own moisture meter AND learn how to use one correctly..
Holland Marine Products out of Canada sells this moisture meter:
For $199.00!! Trust me it will pay for itself the FIRST time you use it. Getting a surveyor out to a boat will cost you a minimum of about $400.00 $600.00 to tell you the thing has decks like sponges that you can;t feel.
With your own moisture meter, and some studying, about proper use, you can eliminate ten boats a day until you find one with dry decks, that you like, and are then willing to commit to a survey on..
Click on the words Holland Marine Products above then scroll down the main page a bit to see the moisture meter..
You can be penny wise and not buy one but TRUST me it will pay for itself during the first use if used properly. I think every boat buyer looking at 30+ foot boats should own one and take the time to learn how to properly use one. Don Casey's book on surveying is also a MUST..
My personal feeling is that if every boat buyer had a moisture meter brokers would smarten up and be a LOT more honest!!! Many brokers have moisture meters and do check decks before listing a boat but then WON'T admit any problems and force you to hire a surveyor $$$$ to find out for yourself.. It's like they are in coo hoots together..
The savvy boat purchaser always comes prepared and owning a moisture meter is the number one thing you can do other than reading and studying books on boat surveying and construction ...
The Pearson 36 is a great boat but not immune to the perils of age..
You did forget one thing though; electrical and wiring (condition, gauge, corrosion, terminations etc.)
______
-Maine Sail / CS-36T
Maine Sail is offline
post #24 of 42 Old 03-27-2008 Thread Starter
eherlihy's Avatar
Aaahhh, the Moisture meter...
At one time, I actually considered buying one of these. However, I am not a surveyor, nor do I have any experience using one. So, the cost of buying one did not seem to be worth it to me. Then I wondered how they worked, so I started researching them a little. I found two great article about the limitations of them here and here. My research led me to believe that unless I was using it ALL THE TIME, it would likeley be a lightweight "doorstop" (reference to the second link) in my hands.
I believe that a better inspection for moisture is to use infrared imaging. There is a good site, showing some great images of an infrared camera used in conjunction with a moisture meter, from a surveyor that uses this technique here. When (if) I contact a surveyor, this will be something that I will look for.
eherlihy is offline
post #25 of 42 Old 03-27-2008
I'm just waiting for this to come and bite TB on his A$$.. I can see it happening... his wife hates sailboats because they heel, and she's going to want to buy a catamaran... then what is TB gonna say.
sailingdog is offline
post #26 of 42 Old 03-27-2008
Señor Member
TrueBlue's Avatar
I'll cross that bridge deck when I get to it SD . . . but 'till then, No more than ONE hull.
That's my story and I'm sticking to it.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #27 of 42 Old 03-27-2008
WinterRiver's Avatar
Ergonomics should be on the list, too.
If the cockpit isn't comfortable or you won't be able to sleep in the berths, there's no need to worry about the moisture meter. If the dodger is exactly at eye level, there will be a cost involved even if it's new and custom.
With everything else that's on the list to check out, it could be easy to forget to climb into the berth or stretch out in the cockpit or imagine steering for a long time. Think about what fit you and your wife, and what didn't fit on OPBs.
WinterRiver is offline
post #28 of 42 Old 03-27-2008
WR's got a good point... if you can't lie down in the berths... you shouldn't even consider the boat...
post #29 of 42 Old 03-27-2008
TAK
TAK's Avatar
Good suggestions..
I did not see any mention of electrical wiring (sorry if I missed it..)
Before turning anything on, (AC unplugged..) I would open up the back of the panel(s) and check for general condition.. neat and tidy? or a rats nest? indicating the owner’s creativity in electricity 101.. Assuming that is in good condition, I would turn on both DC and AC if possible and go through all the lights, plugs, radios, water pressure, Refrg. etc...
As a side note .. After I bought my Caliber, I realized my very well known, highly recommended surveyor in Annapolis missed the 4 extension cords black-taped together to power the water pump..
Good Luck
s/v Mahalo
Caliber #4065
ACM - Eastport MD
TAK is offline
post #30 of 42 Old 03-27-2008 Thread Starter
eherlihy's Avatar
Thanks guys,
As I said earlier in this thread, my wife and I are familliar with this model Pearson.
Also Jody makes a good point too. Feel all the seals.
My wife will do the white glove test(believe me!)
eherlihy is offline
