03-30-2008
Here .. Pull this
Gaff rigs are not capable of sailing as close to the wind as the more common Marconi or Bermudan sloop rigs. Hence, when you are going upwind you end up sailing further to get to the same destination.
Generally speaking, the Gaff rig gets the center of effort a bit lower, which makes the boat heel less. So, you can put a litle more sail area on a Gaff Rig than you can on the same hull with a Marconi rig which offers the opportunity of better downwind performance. The center of effort also moves back a bit however, so you're going to have increased weather helm developing.
You can't tweak your sails on a standard Gaff rig to the same degree that you can on a Marconi rig. But you usually have more sail options on a Gaff rig than a Marconi.
The Gaff rig has an old world charm that (from my perspective) evades the modern Marconi setup, but it is a bit more work to raise and trim a Gaff rig than it is to raise and trim the Marconi.
I have had both, like both. For aesthetics and versatility the Gaff rig wins. From a performance and ease perspective the Marconi comes out ahead.
In the case of a boat like the Flicka, I don't think that you're going to notice a really appreciable difference in performance between the two options. If it was me - I would probably go for the Gaff as I find them easier to repair and/or jury rig in case of mishap.
Good Luck !
