04-21-2008
If all else is equal...sure, take the Autohelm. Hard to find boats that are equal though, there is always extra stuff on some and non maintained stuff on others.
If you are going to be single handing a lot, the autohelm is a big plus. I learned to single without it, and sometimes still do. However, if it gets nasty it is a lot easier with auto handling the wheel during a tack. Or when you have to get a beer, or make a sandwich, or use the head. If you always sail with others you probably will not use it for daysails and short coastal cruising.
Also, unless it is a hydraulic autohelm, it will be very sensitive to sail trim. Most of the wheel pilots like to be in trim or wander a lot.
