Compass 28 - Page 4 - SailNet Community
post #31 of 33 Old 05-26-2008
Ilenart's Avatar
fancy that, post number 100
Ilenart is offline
post #32 of 33 Old 05-26-2008 Thread Starter
Once known as Hartley18
Classic30's Avatar
Dock
Well done!!
I've learnt at bit from you already and you obviously have a lot to add to this forum - keep up the good work!!
Classic30 is offline
post #33 of 33 Old 05-27-2008
tdw
Super Fuzzy Moderator
tdw's Avatar
Originally Posted by Hartley18 View Post
TD, without meaning to break your chain of thought..
Our Hartley is a pig to manouever going astern, to which I've always blamed the outboard, but I'm starting to think that the substantial full-length "keel" could be at least partly to blame.
Is there much difference in reversing manouverability between a full-keeler and a cutaway-forefoot? Or is reversing always an issue until you get to a fin??
.. and I'd love to know if a winged keel makes any difference to docking ability, but I guess I'll find out for myself in a couple of weeks.
Cameron,
Better minds than mine could give you a more technically correct answer but as far as I'm aware it's all to do with waterflow over the rudder. A fin with no skeg has clear flow from prop to rudder so they will steer in reverse. Full keel has seriously disturbed flow so will be a pig, fin and skeg neither fish nor fowl. I've found that fin and skeg will steer in reverse if you are brave, meaning if you give it a bit of stick they will behave but I do add that it takes a brave soul to reverse a 40'er into a confined space at 2000rpm. I am as bold as a lion in the middle of a calm bay practicing my reversing but seem to be more small rodentish when surrounded by a few hundred thousand dollars worth of other people's plastic.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
Understanding and Using the Magnetic Compass Jim Sexton Learning to Sail Articles 0 03-01-2000 08:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Seamanship Articles 0 03-01-2000 08:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Gear and Maintenance Articles 0 03-01-2000 08:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Cruising Articles 0 03-01-2000 08:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Her Sailnet Articles 0 03-01-2000 08:00 PM
