-   Boat Review and Purchase Forum (http://www.sailnet.com/forums/boat-review-purchase-forum/)
-   -   Specific things to look for in a Cal 20 (http://www.sailnet.com/forums/boat-review-purchase-forum/43657-specific-things-look-cal-20-a.html)
lostcoast 05-29-2008 10:15 AM
Hi,
Im new to these forums and sailing as well. On the recommendation of several friends, Im taking a look at a Cal 20 tomorrow afternoon and was wondering if there were any recommended areas to specifically pay attention to (or areas with frequent problems) on this particular boat.
Im pretty familiar with glass boat construction (power) so feel pretty comfortable checking the boat out... well the hull anyhow.
THANKS!
DrB 05-29-2008 11:37 AM
Here are the major things that I would look for during the initial walk through:
Hull - Issues above/below water line: Thru-Hulls: Intake, well bonded, no excessive corrosion. Gel Coat - Dimples, blisters, cracks, repairs, discoloration. Look at the keel/hull joint. Can you see a line? If so, that could indicate a area of closer inspection. Tap on it (hull) with your hand or a small hard rubber mallet. Listen for "thud" sounds which may indicate moisture or delamination.
Deck - Cracks around stanchion bases. Some hairline ones are possible and okay, large ones or ones that have been repaired require more inspection from below. Walk around the deck, do areas feel "mushy" or soft. Tap a few areas with the hard rubber hammer and listen for "thuds". Look for areas of localized discoloration, especially around hardware. Wiggle a few stanchions, do they feel solid or mushy? Spin the winches, do they spin freely with a nice buzz sound or do they bind or have a grinding sound?
Rigging - Look at the rigging holding the mast up. Is is corroded/rusty, have any broken wire? Look at the mast, any evidence of corrosion/blistering around any hardware, flaking paint (if painted).
Running Rigging (lines) - Heavily worn (fuzzy) or newer? Can you look at the sails? Look for excessive loose threads, bagginess, tears or repairs, dirty, etc.
Below Deck - Look for any water stains on ceiling or around any through deck hardware bolts. Does the inside have a strong musty smell? May indicate excessive moisture in the cabin. Check the bilge - Water in it, How much? Color? Salt or Fresh? If the boat has a head, look at it and all the plumbing hoses.
General appearance of the boat will tell you a lot. If it looks in good shape, and not just a fresh coat of paint inside, it was probably maintained well.
Since the boat probably has an external motor, that isn't a significant factor during the initial walk through. However, a boat with an internal motor requires a good look at the motor and its condition.
I am sure others will chime in, but I think that you can get a pretty good feel about a boat in a 15 minutes initial walk thorugh.
Faster 05-29-2008 01:48 PM
In addition to the good doctor's advice, if the boat has not been kept pristine you may see some significant rust on the keel (cast iron IIRC). External rust is mostly cosmetic and can be blasted/faired with a bit of work.
Jim H 05-31-2008 02:10 AM
Specifically, if there is a vent hole in the foredeck, inspect all around it for rot in the plywood core.
Walk on the foredeck-- does it feel strong like a table, or bouncy or flexing.
Cal 20s are famous for breaking the hinges where the spreaders connect to the mast. You can buy new, heavy duty ones to replace the originals. See how much of the standing rigging is original.
What is the condition of the rudder-- wood or fiberglass, solid or water logged.
Keel bolts-- new and stainless, or rusted, swollen and leaking. FYI, the bolts on a Cal 20 are available new and very easy to replace-- they pass through the flange of the keel, but they are not threaded into it.
You can see our restoration sequence of a Cal 20 here--
Cal 20 Restoration
Cal 20s are simply the optimal starter boat for many people. I much prefer them to trailer boats, and the one design aspect have kept good sails and parts available for them. Affordable, but fun and safe to sail.
