A Picture of My New Boat - Page 4 - SailNet Community
post #31 of 39 Old 06-06-2008
Novice
senatorcongressman's Avatar
likey likey
congrats
senatorcongressman is offline
post #32 of 39 Old 06-06-2008
Brezzin's Avatar
Originally Posted by zz4gta View Post
I like the hand held, waterproof, floating VHF. That way I don't have to go down below to make a call. And I can take it with me when I leave the boat.
True, but you want a fixed mounted one as well. You want some height on the antenna if you need the distance. I actually have a fixed mount at the nav station with a ram mike at the helm. But I find that I use the Handheld most of the time.
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
Brezzin is offline
post #33 of 39 Old 06-07-2008
Montenido,
I have a suggestion for an inexpensive GPS set up on a C30... Run your twelve volt line from your breaker to the starboard lazarette, and then up your binacle where you attach the Garmin or whatever. Here's the set up on my C30. It's the only picture I could find...
sailhog is offline
post #34 of 39 Old 06-07-2008
Sailhog-
I see your youngest takes after you a bit... Thank god the mother is pretty enough to offset your gene contribution.
sailingdog is offline
post #35 of 39 Old 06-07-2008
SD, Montenido
I posted this picture for the technical information it conveys -- kinda sorta. Behind the little girl making the pig snout with her thumbs is the coming out of the lazarette. This set up, however, makes the wire an obstacle when climbing behind the wheel, as you can catch it on your foot. A better set up could easily be made. Just haven't gotten around to it yet.
sailhog is offline
post #36 of 39 Old 06-07-2008
Of course, none of that is clearly visible due to the cute kid with the hog snout.
Originally Posted by sailhog View Post
SD, Montenido
post #37 of 39 Old 06-07-2008
Handsome devil
Stillraining's Avatar
Yes I definitely see the merritt of this installation....
The look of shear terror...the look of belittlement... and the look of indecision...
BFWIW...You are a wealthy man...
Stillraining is offline
post #38 of 39 Old 06-07-2008
arenuiwaka's Avatar
I have been using the Garmin 4208 chartplotter for about 6 months, It has been great and I have used it in all weather. I however don't have any other experience with anything other than Garmin. I am a pilot and I have been using Garmin for years in my planes so I think its reliable and really easy to install. BTW I like you boat CONGGRATS!
arenuiwaka is offline
post #39 of 39 Old 06-07-2008
Aeolus II
mccary's Avatar
Congratulations on the new family member! Don't worry about the money...
On my boat's website I have a quote from Mark Twain, "Twenty years from now, you will be more disappointed by the things you did not do than by the things you did." So go out and make some fond memories!
Joe McCary,
Sailing on The Central Chesapeake Bay, West River, MD on my Catalina 27, Aelous II with my wife and friends.
Sailing Blog:
mccary is offline
Making Passage w/o a Rudder wind_magic Seamanship & Navigation 60 07-16-2010 01:23 PM
Construction of a PVC (Divinycell) cored boat Giulietta Sailboat Design and Construction 8 10-19-2007 05:46 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 08:00 PM
Rust Never Sleeps John Kretschmer Buying a Boat Articles 0 02-27-2003 07:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 08:00 PM
