06-24-2008
Get a Porta-bote.
The 12' 6" or 14' versions are cartoppable...and they don't take up much storage space in the off-season. Also, far more durable than any inflatable. The 12' 6" has a cargo capacity of 670 lbs., so will handle two adults, two kids, and their gear pretty easily. The 14' version has a capacity of 807 lbs. I've used the 12' 6" version with a 3.5 HP Tohatsu four-stroke, which weighs 38 lbs. and it can move pretty well with that small an engine. The Tohatsu 3.5 HP will run for about an hour on a tank, which is about a third of a gallon.
If you have a Thule or Yakima roof rack, and get the cargo pod, the boat and pod can go on top of the car, and the oars, benches and transom will fit in some of the larger cargo pods.
