06-27-2008
Bristol 45.5 - AiniA
Not for offshore
I had one of the first n30s for quite a few years and I have a couple of comments. They are a wonderful boat overall and you will not be disappointed in your purchase if you go that way.
1. At our club we did our own masting and dismasting and it is easier with a Nonsuch than a conventional sloop. The mast is heavy to move around when down, but such is life.
2. The cored hull should not be a problem as long as the integrity of the core has not been compromised. The worst case for this is if a rubrail has been attached without fastenings being potted in epoxy. Have a surveyor who knows his stuff look at all the places where holes/fasteners have gone through the hull. There are lots of solid bits in the hull where transducers, intakes and the like should be located - on a boat that has been in use for a number of years you never know.
3. Similar concerns will core rot in the deck. There is likely to be more rot here because there are many more holes in the deck than hull. Small rotten patches are not too hard to fix, but large areas can be very expensive.
4. Terrific coastal cruiser, not really good for extended offshore. The rig is very simple and there are few things to break, but when something does break it is major since there is no redundancy.
5. We did NYC to Bermuda and back and did well, but it was hard to make a third reef work since the end of the wishbone was not supported well in this situation. I had a storm mainsail and separate track installed and this might work but you still have a very long, quite heavy wishbone. I still have the storm sail if you buy a Nonsuch and would like one.
Let me know if you have any questions.
