06-29-2008
The main problem with many of the swing keel boats is that they require periodic maintenance of the pivot pin and raising/lowering mechanism. If this isn't done, bad things happen. Most of those are a bit on the small side for crossing Cape Cod Bay, except in the best of weather—so keep a close eye on your weather windows.
Originally Posted by particlepood
Thanks for the info, I'll be sailing in Cape Cod and the south shore of Massachusetts bay in mostly sheltered waters. I wouldn't be going out as far as Stellwagon bank. The 25 mile cruise would be from Green Harbor in Marshfield to Race Point in Provincetown which is 25 mile 180 deg shot across the mouth of the Cape Cod bay. On some days you can see the humpbacks from the beach.
Is it very common for the swing keels to fall out or bend or is it a lack of stability or rigidity?
Thanks again,
Particlepood
