07-01-2008
RXBOt-
It wasn't a lecture... he's asking for advice, but without knowing what kind of sailing he is going to be doing, it is rather difficult to say whether the boat in question is a good fit or not. If he's planning on living aboard and only daysailing, that takes a certain kind of boat.... if he's planning on crossing oceans, it takes a different kind of boat. I generally don't try to give advice without having a bit of context to base it on.  It is pretty poor advice if it is given without regard to the context of the situation.
While Crowther may have designed a 36' trimaran called a Buccaneer, I don't believe it was ever made as a production boat, much less by Bayliner. I'd also think that the OP would have mentioned it was a trimaran, since that is a rather distinguishing characteristic, and he hasn't said anything about it being a multihull. Unlike you, I'm trying to give the OP relevant advice.
Originally Posted by RXBOT
Hard to believe but 35.75 loa, beam 26, draft min. 2.25. Yes Dog it's a trimaran sail area 821 first built in 74, either plywood or fiberglass. Designed by Lock Crowther from Oz. Built his first boat a tri in 59 while still a teenager. I guess he is quite famous for being a pioneer of multihulls. Dog the OP just wanted some information on a boat not a lecture.
