07-07-2002
Super Moderator
Hunter 356
Jack,
Those pictures of an early 1990''s Hunter that was left unattended in an anchorage exposed to the ocean and dragged onto a beach in storm have been floating around the internet with various explanations of what happened. One description of what happened to the bow said that a cable from a land based heavy truck was hooked to the stem fitting in an effort to drag the boat above the breaking waves. I know of no larger coastal cruising boat that was made to be dragged by its stemhead up a beach. The pictures showed the stem fitting torn from the hull which ultimately brought down the rig.
The other pictures showed rudder that was sheered off of the boat after the boat had backed down on the beach. Much has been made of the broken composite rudder post which was sheered off in the pounding on the beach. In theory the current generation of modern composite rudder posts can be, and generally are sturdier than the SS posts they replace. (This obviously is not always the case and may not be the case in this instance.) They are actually more expensive to produce and are used in new boats because they offer greater strength and can be lighter.
In 1969 my family lost a 1965 Pearson Vanguard in a storm. While the rig remained in the boat, the post storm pictures looked very similar, a beat to death hulk lying on the beach, its keel hung rudder sheered away, and bronze rudder post bent and partially missing.
So, with all due respect and with all of that said, without knowing the specifics of this case, I respectfully suggest that it si hard to make any broad judgements of based upon the photo''s.
As to the 356, it uses some pretty exotic materials in its construction such as Kevlar/vinylester laminates in the bow sections and in some of the internal framing that would not have been present in this earlier model.
Respectfully,
