catalina 30 - SailNet Community
Blogs
Old 07-06-2002
Jemac is on a distinguished road
catalina 30
We are currently considering the purchase of a 1982 Catalina 30. Of course, we''ll have a thorough survey done, but it would be helpful if others of you who own Catalina 30''s of this vintage would let us know what you like and dislike about the boat, what we should be sure to have checked out by the surveyor, and other info you''d like to share with us.
This will be our first boat.
We look forward to hearing from you. Thanks for your help.
Jemac
Old 07-14-2002
colehankins is on a distinguished road
catalina 30
I may be able to answer many questions you may have
Old 07-15-2002
Mike Turner is on a distinguished road
catalina 30
We have an ''81 Catalina 30 and sail in So. California. She''s a great boat! A couple of things to look for:
* Check the deck below the mast for any compression or "dishing." It''s pretty common and not a terribly serious problem unless there are structural cracks in the deck. If so the factory can supply info on the repair -- drop the mast, dig out rotted wood, inject expoxy to fill void.
* Check base of mast at mast step for any aluminum corrosion. "Dust" or minor pitting is pretty common and not a big problem. Watch for any significant pitting (the problem is the alumimum mast sitting against the stainless steel mast step -- galvanic corrosion).
* In cabin, check wood block mast step at very base of mast in bilge. Watch for softness/rot. If needed you can treat with penetrating epoxy to stop rot; but if the wood''s really gone, it has to be replaced.
* Also check cabin top at mast compression post for any sign of cracks, etc.
* Cabin starboard, check alignment of hanging locker doors -- if seriously out of alignment can be a sign that the bulkhead has come adrift from its attachments to the hull. This is potentially a problem as this bulkhead is the attachment of the chainplates to the hull. Check fasteners.
* Make sure shrouds/chainplates have been upgraded from "eye" bolt attachment to "U" bolt attachment on deck.
We''ve had great fun with our C30, hope this works out for you!
Mike Turner
S/Y Amity
Long Beach, CA
catalina 30 new sails jhabaa1 Gear & Maintenance 2 02-15-2004 01:06 PM
Catalina 310 greatwhiteway Boat Review and Purchase Forum 10 07-02-2002 07:42 AM
Catalina 27 or 30 xavier6162 Racing 1 03-01-2002 05:24 PM
PHRF club racing a Catalina 27? Nawlinsguy Racing 2 12-09-2001 11:40 AM
A new catalina 36? paul-e Boat Review and Purchase Forum 32 09-21-2001 06:26 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
