07-28-2008
Pearson 31-2
Triton
She looks better than the 1960 Triton yawl I am looking at seriously as a major project boat (I have a weak spot for yawls).
Four potential problem areas for Tritons:
Rudder cracking (if it's the original wood rudder).
Deck core rot & delamination
Mast support softness, compression, cracks.
Tang cracks, bedding problems.
I believe yours is post external ballast so you don't have the fifth worry spot of keel bolts.
All of these are fixable, as mentioned, but some sizeable investments of your time or someone else's time on your additional investment to correct if necessary. Sounds bad, perhaps, but for a 42 year old boat there ain't many that won't have similar or equivalent problems. I'm 90% convinced I'm going to go ahead with my purchase. There aren't many sailboats WORTH that much work and the Pearson Triton is one that is worth it.
Check out Practical Boat Buying Vol 1 or Spurr's Upgrading the Cruising Sailboat for some good insight on the Triton. Cost you a LOT more to get something as seaworthy new or slightly used and the half model of her on the mantle won't come near looking as good. ;-)
