08-03-2008
The C&C 38 is a big, heavy boat that takes a full crew to handle unless it's set up with pricey gear which... can break. Having to find crew makes boats lose price points compared to others. Having to buy 3/4" sheets instead of 1/2" sheets makes boats lose price points compared to others. Having to buy $80 snatch blocks instead of $50 snatch blocks adds up after a while, too, and makes boats lose price points compared to others. It goes on and on. The 38 is also pretty deep, which limits cruising grounds. Below, the cabin offers a pretty huge space for crew and gear to get thrown about in, since there are few handholds and (in keeping with the goal of racing) little space for secure stowage as originally built. The 35 is much "tighter" in terms of stowage and area below, and therefore safer in a seaway. To compare performance, the 38 rates 114 PHRF on Lake Erie and the 35 (Mk I) rates 129. Neither one looks to be fantastic in light air (see testimonial from sailstoo above) though the bigger boat might be able to snag more breeze with its taller mast. The 33 is a pretty boat that sails well upwind (rating 150) and is obvously easier to sail shorthanded than the 38 would be. The tiny main is ridiculous, however in terms of any drive, and forces having a huge jib to get the boat to move. The 33 can also be quite squirrelly downwind when the pinched transom and IOR "bustle" come into play. I believe Practical Sailor has good input on these boats in their "Practical Boat Buying" books, which may be available in your local library if you don't want to buy them.
