Please Advise me about a sailboat with an older Diesel Engine
I am a newbie at sailing and we are considering a 25 foot Bayfield with a 76 Yanmar YSE8 diesel engine. The engine was rebuilt in 1993. It had new heads and mufflers in 2007.
Here's my question, should I avoid this engine? Is it 32 years old or is it 15 years old? My dreams are modest...I only want to sail in gentle winds with my family on weekends...
Any advice would be greatly appreciated.
Thanks,
Glen
I'll chime in on this one, but first I'VE NEVER OWNED A DIESEL. So take this with that warning.
If the diesel has been well maintained and the up keep has been done annually, I would think the engine wouldn't be a deal breaker. Diesels are know for their longevity, when compared to gas, as long as they're not neglected. Also if this boat is really "the one" for you, and the only thing stopping you is the older engine, you could always have a diesel mechanic perform a mechanical survery on the diesel engine. This will at least give you some peace of mind if the survey comes back good and if it doesn't come back good, maybe give you a little leverage in asking for a lower price...
Well good luck. Bayfields are nice rugged/good looking boats.
My Atomic 4 gasoline engine still runs fine after 41 years. Admittedly, it is basically a tractor engine that likes to to be babied and fortunately I have learned some of the tricks to keeping it happy. You will too with a not-so-old diesel.
Keep the fuel tank clean of sludge and water.
Change the pre-filters often (yearly at least).
Change the oil often (twice a year).
Inspect the water pump impeller.
I have a 1979 Yanmar 15hp. It has been well taken care of an runs very well. Diesels wiil go a long time but you should have good mechanis take a look as replacing it or repairing it can get very, very expensive. My guess is that it is near the end of its useful life.
It depends on a couple things -- How much was the boat used? how much of that was sailing, and how much motoring? how was the PO's maintenance schedule? I had a '77 Yanmar YSN8 in my '78 O'Day (sold 5 years ago, current boat has an '80 Perkins 4108) and a good friend's current boat (8 meter S2) has a 1978 Yanmar YSN8. My Yanmar sufferred a broken valve after 5 days of constant running to bring it here from Michigan (mast down) in 1997. 250 dollar repair. My friend's boat has never had the head off, runs like a champ. Basically you need a survey on the engine unless you know the seller well enough to know his maintenance habits. It may well serve your needs for the next 25 years without a hiccup unless it has been neglected or run 2000 hours a year for the last 20. Get a service manual, get a survey, then decide.
Don't turn down a boat you love based on the age of the diesel. Get a marine diesel mechanic NOT a surveyor to go out with you on the sea trial and put the engine through its' paces. If he says the engine is fine...then buy the boat if it otherwise meets your needs. If he says it is not fine...then walk away...the expense of a new one will be in the $10-15k installed range which you will never recoup.
We have a 1982 cutter with a Westerbeke w21 that has 700 hours on it. A diesel that has been maintained will go at least 5000 hours no problem. If the rebuild was done correctly, you're diesel is almost new.
Thanks to those who responded. I am impressed with the help you provided. I now have a plan and a better sense of options. Wow, this sailnet thing really works! If ever I learn what I am doing (sailing-wise), I'll be sure to help a newbie.
Thanks again,
Glen
I'd be much less concerned about the diesel than I would be about the performance of the boat. Although they are relatively well-built boats, and are definitely "shippy" looking, the Bayfield 25 may well be the slowest boat ever to leave a jetty. Not saying you shouldn't buy it, but go into the purchase with your eyes open.
We have a Yanmar 8hp 1-cylinder engine in our 1977 Hunter 30 that has been, to put it mildly, abused since my dad bought the boat new. He changed the oil only sporadically (and I mean maybe once every 10 years), probably has never had the fuel drained or fuel filter changed, minimal if any service done to it. It still runs, although it needs a little starting fluid (probably bad compression). These engines can take a lickin and still run forever. If it starts up well and there's not weird scents or smoke emanating, you should be just fine.
If the engine is in bad shape, wouldn't it be a lot less expensive and even a bit easier to just go buy a 9.9 outboard?
Andy
Related Threads
1.7M posts
173.8K members
Since 1990
