09-10-2008
Originally Posted by christyleigh
That depends on the pivot point of the tabernacle. My first pilothouse was a Nimble Arctic 25 Pilothouse Sloop and the very beefy 1/2" thick aluminum square captive tabernacle had the pivot pin about 2 feet off the deck so the mast could lay on or even above the pilothouse roof.
To my knowledge no tabernacle setup like this was factory. Anything is possible but... The standard spar on these boats is quite beefy. The Spartech spars on later boats is something like a 4 x 7 oval cross section with almost a 1/4" wall section. The wire is all 1/4" The mast is quite heavy and with furling gear for jib, and maybe main would be a real trick to step without the assistance of a crane. This is defiantly not a trailer sailor!
thanks sailboy21 you gave me some needed info, Sounds like you have some experience with this boat. If so, whats the forward view from the two helms, are both satisfactory?
everyone says this boat is a slow sailor and doesn't point high is that really a big deal all things considered. Any idea what the fuel use will be with a volvo md11c at cruising. You mention rot on the bottom and edges, I'm confused, can you explain in more detail what I should be aware of?
TJ
Lots of good info here: rawsonownersnet : Rawson 30 Owners' Network
I don't have a pilot house, so I can't comment on the two helms. As far as fuel economy it should come in in the normal range for displacement boats this size. I would suspect .6 - .8 GPH at 6 knots but your experience may vary. Since the bulkheads are glassed in the plywood between glass layers may hold water if there was a persistent leak. This goes for any boat of similar construction. They point just about as well as any other bulky full keel cruiser. It is not a sport boat, but they have won offshore races and can do 120 mile days offshore in the trades. If you are thinking about this boat, one of your top priorities should be looking for a safe, well built, tough as rocks (literally) cruiser that will take you anywhere you want with dignity.
