Old 09-21-2008
lonnywinn is on a distinguished road
Help! Buying a Newport 27, looks like hull warp??
Im in the process of buying a 1986 Newport 27'. As I was inspecting it I noticed that she was sitting a little forward on the trailer. After looking closer I could see that where the hull rests on the pads there is some warping inward.
So my question is, Is this normal for a trailered boat of this size?? I've never owned a fixed keel so i'm not sure if I should worry about this...
If you look at the picture you can see it. Its not massive but I can tell it's there. if it is an issue is it difficult to fix??
Im planning on doing the title transfer early next week and really need to know from some of you pro's what I should do.
Thanks!!
Old 09-21-2008
In all likelihood this is due to too much weight being supported on the pads, along with the pads located away from supporting internal bulkheads.
Whether it's a serious problem or not depends on how long it's been like this (on the trailer) and whether the deflection has caused any internal fracturing of the glass.
I'm pretty sure the N27 is a single skin (ie non-cored) hull and this minor deflection may be nothing to worry about once it's off the trailer and in the water. If it returns to it's original contour when lifted or floated off the trailer, you may be fine.
Are you having this boat surveyed? You should, and the surveyor will be able to better advise you since he/she will be there to observe in person.
1984 Fast/Nicholson 345
Old 09-21-2008
I think she has been on the trailer for quite a long time, but oddly, the current owner could not tell me since she never launched her.
I'm trying to find someone around Coeur D Alene, Idaho to do a survey but thats harder than it sounds
Thanks for the info!
Old 09-21-2008
small amounts of hull deflection is pretty common on sailboats on stands.
Old 09-21-2008
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
If it's a flat spot or even dished in slightly it should return to it's original shape once floated. The plastic between the glass fibers has stretched a bit and this is an elastic deformation which will rebound if the hull is put into the water (the load will be spread across the entire hull; not just the loaded stand).
JMHO; if you are worried about your investment you should have a survey/seatrial. If you can put it in the water for 6 months or longer you could then re-haul the boat on a sling lift and check it again; but that's not easily done in Idaho I'm sure.
go to:
newportsailboats : Newport Sailboats - For Owners and admirers of Newport Sailboats for more info/advice.
Old 05-07-2009
In case anyone ever wondered...I hauled her and the warp is all gone. Was just from sitting on the trailer too long
Old 05-07-2009
Irrationally Exuberant
arf145 is on a distinguished road
Thanks for closing the loop on that! Glad it worked out for you.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 05-07-2009
Good to hear how it all worked out... When you posting pictures of her ready to sail???
Ryobi vs. Makita vs. Poliglow?? CLucas Gear & Maintenance 61 3 Weeks Ago 06:02 AM
Theory on cause of Fiberglass Hull Blisters travistowle Gear & Maintenance 121 10-31-2011 08:59 AM
Glassing hull GreenEarth General Discussion (sailing related) 18 06-19-2009 11:52 PM
Had our hull surveyed today danielgoldberg Sailboat Design and Construction 10 05-25-2008 12:13 AM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
