Oday 22/23 vs 25/26 - Page 2 - SailNet Community
post #11 of 16 Old 10-01-2008
BarryL's Avatar
stepping the mast
Originally Posted by firefitn View Post
how difficult is it to step the mast and attach the boom? Can it be done alone? Are there winches or how are they set up?
I'm not familiar with the O'day set up, but I can describe how you step the mast on a Catalina 22.
When trailering the boat, the mast will sit on the bow and stern pulpits. To step the mast you need to move the mast aft, so that the mast butt is at the mast step. I built a simple mast crutch, because the top of the mast (now moved quite a bit aft of the stern) must be elevated. With the top part of the mast resting on the crutch, it was simple to insert a pin through the mast step and base of the mast. Now you can get ready to raise the mast.
Since the mast on a Catalina 22 isn't that heavy, a STRONG person could raise the mast by hand. The side stays prevent the mast from falling over and the backstay will prevent it from falling too far forward. I raised the mast like that once or twice, but it was very difficult. An easier way was to tie a line around the forestay and connect that to the winch on the trailer, that is normally used to winch the boat back onto the trailer. With the winch on the trailer it was pretty easy to crank the mast up. When the mast was vertical you connect the forestay and disconnect the line.
You tension the forestay, the other stays and shrouds are fine. It's pretty easy to put the boom on, just clip the end of the boom to the topping lift, then put the pin through the gooseneck at the mast end. I used to leave the mainsail on the boom when the boat was trailered.
Put the outboard engine on, put the rudder on (if the ramp wasn't too steep I could leave the rudder on the boat), back down the ramp, float the boat off, pull the trailer out and you are ready to sail.
After doing it a few times I could go from arriving at the marina to motoring away from the dock in about 1 hour. Nothing was that difficult or complicated, but there is a good amount of things to do. And expect to take at least the same amount of time at the end of the day when the boat has to go back onto the trailer.
Make sure you note that as the boat gets longer, the weight of everything goes up quite a bit faster. I believe that an Oday 222 weighs 2200 lbs, and the 25 weighs 4800 lbs. The extra 3' of length doubles the weight of the boat.
For me, trailering was a real hassle, and after 1 year of doing it I got a mooring and was much happier.
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #12 of 16 Old 10-01-2008 Thread Starter
thank you very much. That was very helpful. I grew up around milwaukee, and if i lived there i probally would look at a slip, however since i live about 2 hours from the nearest place to sail i will need a trailer sailer for now. Anyone know the weight of the mast on an oday??
firefitn is offline
post #13 of 16 Old 10-01-2008
sailboy21's Avatar
thank you very much. That was very helpful. Anyone know the weight of the mast on an oday??
I never put my O'Day 25 mast on the scale, but I could lower & raise it by myself, and once lowered lift it from the center and carry it by myself. I am not exactly a heavy hitter so it can't be too much, 50-70 lbs maybe? I sure can't do that with the Rawson mast.
sailboy21 is offline
post #14 of 16 Old 12-02-2008
If you really have to trailer that much I wouldn't consider anything over 23'. I owned one for 25 years, and getting on and off the trailer was never enjoyable (if we did it more frequently, it may have become easier--we launched in the spring and retrieved in the fall). I think it's the "Practical Sailor's Book of Used Boats" that has the remark along these lines: "the 23' O'day is a great pocket cruiser in the water, great when on the trailer, but hell in between". In my opinion, stepping the mast is not a solo experience--a minimum of 2 to avoid injury or damage. The 23' is fine for 2 people overnighting so long as you're willing to crouch down in the cabin--I'm 5'7" and adequate headroom was the #2 reason I moved up to an O'Day 27'. We have slept 3 adults and 1 child on the boat--it was helplful that everyone was very friendly and not overly modest--the head is at the head of the V-berth. But I loved the boat--25 years worth--and spent very little money maintaining it.
JohnDunton is offline
post #15 of 16 Old 12-02-2008
Unpaid Intern
josrulz's Avatar
My family had an O'Day 23 when I was growing up. We only trailered it for winter storage. We could have trailered it for weekends (instead of the slip) with a lot more work of course. My point is only that I don't think we'd have considered weekend/daysail trailering with a 25.
All that said, we really loved our 23, and cruised for as long as two weeks with a family of 4 (my brother and I were fairly young). Later we moved up to an O'Day 28 when our family started to outgrow the 23, and made trips as long as 6 weeks on that boat (Virginia Beach to Newport and back), though it sounds crazy to me now!
josrulz is offline
post #16 of 16 Old 12-03-2008
AEOLUS II
WouldaShoulda's Avatar
Once I determined that I would keep the boat in a slip anyway, I went right for the O'Day 272. When the Bay picks up to 2+ feet I'm glad I did!!
22-26ft boats are just too big to trailer regularly. Opinions vary.
Most boats I know of in this range are trailered only to the lot and back to the slip twice a season after the owners realize what a PINA it is to step the mast every time they want to go out.
For me, a trailer boat must be -20ft.
Anything bigger/heavier will wind up in the slip. If it winds up in the slip, you may as well get a bigger, more comfortable boat.
That's how I wound up with a 272.
(But it took nearly three years of thinking about it to come to this conclusion)
WouldaShoulda is offline
O'Day '25 or '26 firefitn Boat Review and Purchase Forum 0 09-29-2008 09:36 PM
Oday 22 Ostervilleboater General Discussion (sailing related) 5 11-02-2007 09:09 PM
ODay 27 for $500? Decent boat? 7tiger7 Boat Review and Purchase Forum 11 02-13-2007 10:08 PM
O''Day "rOnDAYvous 04" maestro General Discussion (sailing related) 2 07-11-2004 05:50 PM
Catalina 27 vs Oday 272LE ryanpsu21 Boat Review and Purchase Forum 3 12-21-2001 05:18 AM
