Old 10-17-2008
jskrypek is on a distinguished road
Buying a Hunter 31 - Crooked Keel
I was looking at a Hunter 31 that had a recent survey and it says the keel is crooked. Is this something I should be concerned with? Can it be fixed? The survey shows the boat to be in generally good condtion. It seemed a little odd to me the way it was written with nothing else damaged. Attached are commentsfrom survey,
"The vessel was designed with a deep keel, which was an option from the standard shoal keel. There were signs of past groundings and the areas had been filled with the fairing compound. The keel was slightly off center, most likely from the grounding. Since the keel was supporting most the vessels weight, there was no separation in the keel to hull joint. I would recommend the joint be inspected once the vessel is lifted fro the stands. If there were any separation I would recommend that the keel be rebounded to prevent any water penetration. The keel was secured to the vessel using stainless steel keel bolts. The keel bolts were corrosion free and appeared tight. The forward and aft bolts were connected to the vessel grounding system. There were no
signs of cracking or damage to the fiberglass around to keel bolts. If the vessel has been grounded hard, it is common to see damage around the keel bolts. There was no damage found around the bolts in this vessel."
Old 10-17-2008
petegingras's Avatar
petegingras is on a distinguished road
Given the assumption that you're not the last owner of this boat, do you feel comfortable that someone is going to buy/take it off your hands in the future? Also consider if you don't know why it's off center, will the next buyer be satisfied with the unknown.
Lots of boats out there, the discount on this one (my assumption) does would not entice me to outlay the money.
Keep looking, it's going to be a long winter recession.
s/v Libertine
Hunter 44DS
Old 10-17-2008
sailhog has a spectacular aura about sailhog has a spectacular aura about
Just walk away from that boat.
Old 10-17-2008
JohnRPollard's Avatar
Moderator
Ditto.
If there has been a grounding serious enough to cause the keel to become "crooked", the current owner should have it fixed with an insurance claim. This is not the sort of problem a responsible owner passes off to the next one.
And would you want a boat that had experienced such damage, even if it had been fixed? Maybe, but usually at a discount.
Old 10-17-2008
Brezzin's Avatar
Brezzin is on a distinguished road
Send a message via AIM to Brezzin
I agree with all of the above. Here's the thing. Most if not all Hunters have a 100% lead keel, not encapsulated. During the grounding, the lead deformed. Wouldn't hurt the bolts but a noticeable dent would incur. Most people would take a hammer and do the best they can to reform the lead. It wouldn't be perfect. Putting Bondo on the keel tells me that the PO is hiding something like maybe a chunk of lead got ripped out.
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
Old 10-17-2008
DrB DrB is offline
DrB is on a distinguished road
My rule is this......
on any production boat, if there is ANYTHING that is wrong with the integrity of the hull, rigging, or deck, I go elsewhere. Not worth the aggravation and time or cost to get repaired, no matter how inexpensive the boat is. A bent, twisted, skewed, or crooked keel is a major issue.
Run.
DrB
Old 10-17-2008
If it hit and grounded hard enough to need bondo on the keel to fair it... RUN.
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 15 03-20-2008 04:36 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
