Boat Inspection Trip Tips - Page 19 - SailNet Community
 31Likes
post #181 of 201 Old 03-25-2014
Thumbs up Re: Boat Inspection Trip Tips
Wow! I am starting to look for my first boat and your list is great!
I had some conversations with experienced boat owners and everything they noted as a major item to look for is on your list, such as delamination and rudder issues. I was also told to watch out for models with a rudder that is lower than the keel because when the boat hits the bottom of the bay (as it will in the Barnegat Bay NJ) the rudder will take a bigger hit than the keel will. And the keel should be the one taking the hit.
thank you so much for this list and i plan to print it for sure! :-)
Christina
ChristinaO is offline
post #182 of 201 Old 05-09-2014
Tartan 27' owner
CalebD's Avatar
bump
Everybody has one:
CalebD is offline
post #183 of 201 Old 08-03-2014
Thank you for all those points to check. I had a basic idea as to what to look at but you had a lot more than I would have considered. Well done!
caperss is offline
post #184 of 201 Old 09-05-2014
Learning the HARD way...
eherlihy's Avatar
I've been mulling adding this one to the list for some time. All of the keel horror stories that have popped up of late have made me decide to add the following to the list.
If you are looking at an older (10+years) boat with a bolt on keel, I strongly suggest that you add language to support the following to the offer to purchase. IF the deal should get to the point of a survey, that as part of the survey that you remove and re-torque at least three of the keel bolts.
Here is why;
When I went to look at my current boat, with the intent of purchasing, here is what the bilge looked like
and here are the keel bolts;
Note the manual pump in the above picture... There was a "little" water in the bilge, and this pump was right here when I looked at the boat on its mooring.
Not too bad - or so I thought...
I eventually made an offer on this boat, and when it went to survey here is what the keel looked like;
Pre powerwash;
Post powerwash;
Something struck me as odd about the keel, and the way that it sat in relation to the hull... After much insistence to the surveyor, and the broker, and the owner, and the yard manager, the surveyor checked it out...
Sure enough, the keel was loose, and the bottom would move about " from side to side. Not a lot, but enough to kill the deal.
The owner faced with this prospect wisely decided to repair the problem and go from there. He had the keel dropped, and here is what we saw;
Four of the seven bolts were TOAST
The only way that this would have been caught, if I didn't make such a fuss, would be to remove, and re-torque several of the keel bolts.
The owner paid over $9500 to have this situation addressed by the yard. Better on his dime than mine, or yours!
Slayer, davidpm, seaner97 and 2 others like this.
eherlihy is offline
post #185 of 201 Old 09-09-2014
Boat Bum
Absolutely awesome thread. Particularly since I'm about to launch a 10-day keel kicking tour of southwest Florida. Here's my question. Since I have a dozen or so yachts to visit and given the exhaustive nature of the list, how long should it take to look at a prospective boat? And how many should I be able to effectively see in a day (given that they are all within a few miles of one another)?
Thanks for the input.
JT
JTSmith is offline
post #186 of 201 Old 09-09-2014
eherlihy's Avatar
Plan to spend an hour, looking at every boat on the first pass. Do not make an offer on the spot, unless you know that it is the perfect boat and perfect deal for you. (IMHO there is no such thing, but what do I know...)
After you have seen a couple of comparable boats, re-visit the one that you really like, and spend another hour, or two.
eherlihy is offline
post #187 of 201 Old 09-30-2014
Originally Posted by captbillc View Post
i have mentioned this in other threads. as a retired diesel mechanic, one of the first things i do is take off the oil filler cap. if it has water dripping from it the engine has water in the crankcase
Could one put in a pcv (positive crankcase ventilation for those who dont know) valve so the moisture could be drawn in thru the engine instead of being trapped and accumulating inside the crankcase?
fstarocka is offline
post #188 of 201 Old 11-18-2014
On inspection of a trawler recently I found this?? Port engine was a ford lehman while starboard was a perkins.....!
Never have seen this before. So what do you think about dollar value of this boat?
DanBat is offline
post #189 of 201 Old 01-03-2015
Slayer's Avatar
Sailingdog, I know this was posted some time ago, but this is a great thread and I want to thank you.
Slayer is offline
post #190 of 201 Old 01-03-2015
eherlihy's Avatar
Glad to read that you enjoy the thread. However as an FYI - SD hasn't been here for well over a year.
Also, after the sh!t that some here gave him when Maine Sail told us that SD's boat, named after his deceased wife, went up in flames last year, I seriously doubt that he'll ever be back.
eherlihy is offline
What's your biggest bonehead move sailing? CharlieCobra Seamanship & Navigation 613 07-19-2016 08:10 PM
The Joys and Pitfalls of Buying a New Boat - Part 1 Lin & Larry Pardey Buying a Boat Articles 26 01-12-2015 10:59 AM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
Understanding the Racing Rules, Part Three Dean Brenner Racing Articles 0 09-09-2002 08:00 PM
The Balance of Hull and Sails Steve Colgate Seamanship Articles 0 05-25-2000 08:00 PM
