Boat Inspection Trip Tips
233K views 204 replies 108 participants last post by  Minnewaska
#1 · (Edited)
After reading a bit about what people think is or isn't necessary when going to look at a boat... I decided to put together this thread.
Please note
: This thread is about going to visit a boat to see if it is worth looking at further. It is not designed to replace a proper survey and sea trial. This type of trip is what you should do to see if it is worth making an offer on a boat and spending the money on a survey and sea trial. IMHO, you really need to have a survey done by a competent surveyor. YMMV.
When you're going to look at a boat, as a possible future purchase, I would make some recommendations about what you should and shouldn't do. I would ask that anyone else chime in with recommendations they have as well. I'll edit this post to add the ones I think are most important. :)
Basic Inspection Kit
First, put together a kit of tools for your boat visit. The kit should include the following:
  • Small Notebook-reporters notebooks or pocket-sized Moleskines are excellent choices for this.
  • Pencil-preferably .5mm mechanical for making notes and sketches in notebook
  • Small tape recorder-preferably with a lapel mic with windscreen, to record your visit to the boat, as it is often easier to make notes by speaking than writing when looking at a boat
  • Digital camera-I prefer the small pocket sized Olympus Stylus SW series, as they are waterproof, shock proof and have a decent lens on them
  • Tape Measure-Preferably a 25-30' tape
  • Small Flashlight-Preferably LED, like the Gerber Omnivore or Firecracker
  • Pocket Multitool-Get a good one, like the Leatherman Surge
  • Phenolic Resin Hammer-a small one will do
  • Small Magnet-preferably one with a lanyard attachment
  • Inspection Mirror-preferably one with a telescoping handle
  • Small Volt-Ohm multimeter-preferably digital with a rubber casing
  • Moisture Meter-see section below
Additional Supplies:
  • Clean White Rags
  • Awl
  • Waterless Hand Cleaner Wipes
  • Spray Cleaner (like Fantastic)
  • Burgundy Scotch Brite Pad
The Trip
First Impressions
Now, when you get to the boat, take some photos of the boat as you approach it... Turn on the tape recorder and speak clearly about your first impressions of the boat. Make sure you get your first impressions down. The human brain is a weird thing and often the first impressions are the best ones... and there's usually a reason for them.
Systematically go through the boat from bow to stern, from top to bottom, recording what you find either on the tape recorder or as sketches and notes in the notebook, and document everything with photos using the digital camera if at all possible. If you have specific requirements, use the tape measure to take measurements.
Don't forget to note the make and model of the various equipment and parts aboard the boat. Some pieces of equipment, like specific models of engines and such have known weaknesses and specific problems to be aware of.
The magnet is to be used to check stainless steel hardware. If the magnet sticks, it ain't marine grade stainless. Austenitic stainless, which covers most marine grade stainless steel, is non-magnetic and includes 304 and 316 grades of stainless. The cheaper martensitic stainless is magnetic.
The flashlight and inspection mirror are used to look in nooks, crannies, deep unlit lockers, the bilge, engine compartment, etc. Looking in lockers and such can often tell you a lot about a boat's true condition, since many people will spruce up and clean the interior of a boat for sale, but will often forget to do the same for the less visible spaces. A good example of what you may find is traces of a visible waterline in the higher lockers may indicate that the boat was sunk at some point.
Tapping the deck with the phenolic hammer near stanchion bases may give you an indication if the deck has started to delaminate or has a wet core. Most boats have a cored deck and stanchions are often places where the water intrusion can start due to the loads that they're often subjected to. Caution: If you are not skilled with a phenolic hammer please DO NOT go pounding on an Awlgriped deck!! They are used for TAPPING not pounding.
Most manufacturers do not do a very good job of potting the fasteners or deck area around the stanchions or other deck hardware, especially on older boats, made when the water intrusion problems weren't well understood.
Look for cracks in the gelcoat-most spider cracks are normal and often due to the gelcoat being laid too thickly. Parallel cracks in the gelcoat, which often indicates stressing of the fiberglass there. Star-shaped cracks in the gelcoat are usually the result of an impact.
Look for flat spots in the hull or places where the hull doesn't follow a natural curve. These can often be indicators of previous damage or bad construction. Often, places where the hull isn't following a fair curve are due to bulkheads being improperly glassed to the hull and causing a hard spot-which can cause the laminate to hinge along the hard spot and results in the laminate fatiguing prematurely there.
Check mechanical systems to see if the parts that should move do, and that the parts that shouldn't move don't. :) If something sticks, like the tiller, and shouldn't-it is probably an indicator of something wrong or about to go wrong. Excessive play is often an indicator of wear and that something may need to be repaired or replaced soon. If a cabin door or cabinet door doesn't open or close smoothly, it may mean the hull and deck have changed shape and causing it to bind-this can often happen if a compression post has started to weaken.
The multimeter can be used to do some quick checks on the electrical system. If you don't know how to use one, take a class at a local vocational/technical school and learn-you need to know how to trouble shoot electrical problems using one if you're going to own a boat.
Go through the boat and open every locker if at all possible. Lift settee cushions. Look in the bilge. Photograph the rig. Get detailed photos of the chainplates, the rudder attachment points, the steering quadrant and other important pieces of equipment.
As for the pocket multitool... you'll figure out why I included it in the kit... they're just too damn useful not to have one around. I carry the Leatherman Surge with me almost 24/7, except when I know I'm going through airport or federal building security. The blades on it are just about long enough to qualify as a felony if carried in a federal facility. :)
Going Aloft
I generally won't go aloft on a boat that I'm a complete stranger to, unless the rig is vouched for by someone I know and trust.
Also, I doubt most owners would let you go up the rig given the liability issues if the rig should fail and you get injured. Finally, many boats are on the hard when up for sale, and going aloft on the hard is a really, really bad idea IMHO.
That is why I recommend taking photos of the rig from the ground. The amount of detail you can pull off of a 8-10 MP image nowadays is astounding, even if the camera only has a fairly short focal length lens.
Moisture Meters
If you are in the market for a 10k+ vessel do yourself a favor and invest in a moisture meter. It will pay for its self the first time you use it and rule out a boat!!
Surveys run $600+ clams, moisture meters are $169 clams. If you found a boat you really loved but the surveyor came out and found moisture your out $600 if you do your own "checking" you can rule out many boats safely without a survey and with each boat you rule out die to sever moisture the meter costs less and less until it's free! When you are done simply sell it here on Sailnet to another member or keep it which is what I'd suggest!
Please do NOT listen to the neigh Sayers like David Pascoe on this subject. He is a surveyor who DOES NOT want you to own a meter. He uses scare tactics and discuses how "difficult" it is to use one. That is complete BUNK! Using a meter, to a level where you can rule out a boat with severely wet decks, takes about a half hour to learn! More accurate and detailed use takes more time but that is not what you are after in this stage.
Trust me he and his cohorts WANT to survey three or four boats for you before you find one to buy. My buddy Eric surveyed five boats before finding one in salable condition. He spent over 2k in surveys. He could have ruled at least four of these boats out, if not all five, with about a half hours worth of reading and a $300 meter saving $1700.00....
I use an Electrophysics CT33 moisture meter. This is basically the SAME EXACT meter as the $325.00 J.R. Overseas GRP33. The only difference I know of are the graphics on the analog display. As long as you don't mind ordering from a Canadian company you can save HUGE money. The current price for the CT33 is $169.00 plus shipping from Canada. Oh and don't forget to order the calibration block @ $10.00..
So $169.00 - CT33 Moisture Meter
$10.00 - Calibration block
$9.00 - US Shipping
Total $188.00 Delivered
$169.00
Electrophysics CT33 Moisture Meter Ordering Informationn (LINK)
If you want fancier analog graphics $325.00:
As Maine Sail says: "when you DIY the tools are FREE!! There is NO excuse for anyone investing more than 10K in a new boat to NOT own a moisture meter.." I agree with him. Owning the right tools makes almost everything you do easier. :) BTW, his article on the CT-33 is located HERE.
Specific Inspection Areas:
#1 Sails & Canvas
- If the sails are on board find the UV cover or luff end of the head sail and scratch the threads with your fingernail. If they fail or break the sails need at a minimum re-stitching. If you can find the head board of the main sail,it sees lots of UV as it's not folded into the sail when flaked do the same here. Do the same for any canvas..
#2 Driveline - On inboard powered boats grab the prop and wiggle it back and forth up and down. If there is any play the cutlass bearing is mostly shot and will need replacement.
#3 Driveline - Inspect the strut, prop shaft (if bronze) and prop for any signs of dezinctification. This will appear as areas of discoloration more pinkish or coppery in color as opposed to the gold hue of bronze. A Scotchbrite pad is a good thing to add to the inspection kit as it will allow you to get down to bare bronze.
#4 Rudder -Grab the rudder and move it from side to side and fore and aft. If there is significant play the bearings or bushings may be past prime.
#5 Rudder - Move the rudder by hand from full port to full starboard. If you feel any difference in resistance it could be a bent shaft or steering gear issues.
#6 Steering
- Inspect the entire steering gear assembly and look for excess play or "meat hooks" on the steering cable. Make sure the wheel brake works. A broken wheel brake, or one that does not have adequate locking to prevent you from turning the rudder by hand, means the rudder was allowed to move freely at the dock or mooring. This is BAD and adds to unnecessary premature wear and tear on the entire steering system.
#7 Steering
- Inspect the rudder stuffing box. You are looking for signs of drips or leaks. they will usually run from the top of the rudder packing gland down and will be green in color if it has a bronze rudder packing gland.
#8 Rudder - Look for any rust colored drips emanating from the rudder. This is a good sign of water intrusion.
#9 Keel - Look for any signs of water seepage or discoloration stains along the keel to hull joint. Leaking keel joints lead to crevice corrosion of the keel bolts and can be a bad situation.
#10 Keel - Look in the bilge for any signs of un-sealed screw holes, possibly left over from a float switch or bilge pump, with brownish rust stains around them. This could mean the boat has a plywood laminated keel stub that has been moisture saturated. If the stub has wood and it's wet the keel bolts will likely be suffering from a good deal of crevice corosion.
#11 Keel - Look at the keel bolts and make sure they are no circular stress cracks emanating outward from the backing plates. This is another sign of a rotting and compressing keel stub. Solid fiberglass does not compress enough to create circular stress cracks.
#12 Bulkheads - Using a Awl (please be courteous and do this in an inconspicuous area that can not be seen) poke the areas around the chain plates lightly. If the wood is rotten the Awl will sink in. Do the same around the bottoms of the bulkheads where they meet the bilge.
#13 Glassed in Bulkheads - Inspect all tabbing and make sure NONE of it is peeling or broken free from either the hull or the bulkheads. Do your best to look at the entire mating surface and this will usually require the flashlight and inspection mirror. If you notice any discoloration of the wood lightly poke at it with the Awl. Look for any signs of the teak veneer bubbling or lifting. This is always a red flag for moisture in the bulkheads.
#14 Screwed in Bulkheads - Many production boats used bulkheads that are screwed in place. Make sure the screws are entering at a 90 degree angle to the wood. Screw heads that are cocked or off the 90 degree angle, and if there are more than just the occasional one, are a good indication the bulkhead has been over stressed and has moved. Awl same as above and PLEASE be polite about your use of the Awl!
#15 Deck (Under-side) - Do your best to remove anything that will get you to the backing plates of deck hardware. Please do not dismantle the boat! This is only for areas of easy access. If you can unzip a headliner for example, and the zipper does not stick, visually inspect deck penetrations for any signs of "coffee drips". Any brownish drips or brownish colored stains dripping from through-bolted hardware or any holes on the underside of the deck are signs of a seriously deteriorating rotting deck. If you see "coffee drips" in more than one location walk away and find another boat..
#16 Seacocks - Visually inspect the "balls" from outside with a flashlight and look for any signs of corrosion. If they have handles that turn like your hose spigot at home know that they will need to be replaced because they are gate valves. Real seacocks should have handles that turn only vertically to be in-line with the valve and horizontally to be in-line with the hull only. Turn the handles and visually make sure the balls are opening and closing from outside the boat and make sure they turn freely.
#17 Seacocks - Check for a UL Marine rated listing and dezinctifacation (coppery pinkish coloring)
#18 Seacock Backing Blocks - Poke these with the Awl. If they are soft they are wet and will need replacement. The Awl should not "sink in" under light pressure.
#19 Hoses - Visually inspect hoses, including exhaust hoses, for any signs of dry rot, cracking or reinforcement wire bleed or break through. If you see rust spots mid hose this is a good sign that the reinforcing wire is rusting inside the hose. Check for double hose clamps at all bellow water fittings. Also check to make sure there is no clear, un-reinforced hose that leads to any through hull fitting.
#20 Seacocks - Check for a UL Marine rated listing and dezinctifacation (coppery pinkish coloring).
#21 Engine - Check the oil and make sure it was recently changed and that it is clean and not black. An owner that puts a boat away, or lists one for sale, with dirty oil, is also an owner that does not maintain the vessel to a good standard!
#22 Engine
- If you've checked everything else, and are a VERY SERIOUS BUYER, remove the engine/heat exchanger zinc and make sure there actually is one and that it is in good condition. DO NOT do this with the boat in the water and the seacock open and do not do this if you are tire kicking this vessel. Ideally this should be left to the surveyor but most don't do this!
#23 Engine - Using a clean white rag run it under the engine any where you can reach. If you find a drip record it in the notebook and jot down it's location. Turn the rag to a clean spot and continue. Many owners will spot clean an engine to hide oil leaks. The rag trick usually finds them.
#24 Engine - Wiggle the engine and visually inspect the motor mounts for dry rot or oil degradation. make sure the motor mounts are still working and not cracked.
#25 Engine / Fuel - If the boat is equipped with a fuel/water separator device such as a Racor. Use an empty Coke bottle to crack the pet **** and drain off just a touch of fuel. If it is laden with sediment or all you get is water this is a bad sign. Do NOT drain the entire bowl just a quick crack of this pet **** will show you what you need to know and won;t require the owner re-bleeding the engine. Be polite and clean up ANY fuel drip with the spray cleaner you brought. Even ONE drop is being impolite and rude diesel stinks!!!
#26 Winches - Rotate the winches and make sure they rotate freely and smoothly. Wiggle them side to side, especially if they are aluminum. There should be NO play in the drum. Any play in an aluminum winch is a good sign that the bearing mating surfaces are worn or corroded due to dissimilar metals corrosion. DO NOT overlook this, winches are big $$$$$$$!
#27 Blocks Sheaves - Make sure all blocks and sheaves rotate freely and are not frozen.
#28 Running Rigging - Look for any signs of chafe and wear especially halyards. Scratch the surface of the lines jacket with your fingernail and if threads give way or break it is time for new running rigging.
#29 Portlights
- Look for any visibly signs of leaking.
#30 Lifelines - Look for rust / corrosion at the fittings and between the white jacket of the wire and the swaged fitting.
Warning Signs:
If the boat owner doesn't want/allow you to do this... it may be that they are hiding something. A boat owner who is proud of how well kept and maintained his boat is should have no problem allowing you fairly complete access to the boat and its systems.
Walk the Docks
Once you've gone over the boat with a fine tooth comb... walk the docks and talk to the other marina residents. They can often give you a lot of information about the boat.
  • Was it used regularly or was it a dock queen?
  • Did the owner come out to check the lines and fenders before and after a storm?
  • Did the owner have regular maintenance done to the boat?
  • How long has it been for sale?
All this stuff can often be discovered just by being friendly and talking to other people at the boat's marina.
When you get home
Put everything aside for a day...and then come back and look at it... this gives your subconscious mind a chance to process what you've seen and things that you may have not realized on the initial trip may jump out at you.
If you get a hunch about some equipment or part on the boat, look at your photos and notes about them and see if you can figure out what your subconscious is trying to tell you.
Don't forget to do a bit of research on the various pieces of equipment you saw on the boat to find what specific problems are common to them.
What to do next:
If you really like what you saw and didn't come across any glaring warning signs, it is probably time to make the offer. When you make your offer, ask for maintenance records, and make the offer subject to survey and sea trial.
Remember, if you're married or have a significant other... GET THEIR INPUT. If you don't, you probably will regret it in the long run. :)
I hope this helps.
See less See more
3
#3 ·
thanks Zanshin. :) I hope it helps some of the people that have are looking to buy their first boat....especially if they're buying used. :)
#4 ·
I'm buying my 2nd used boat and the first time around I restricted myself to opening things up and taking pictures (lots and lots of them) - then writing down notes once I left the boat. That wasn't good enough, so I will take a more structured approach and start off with your system. Would you bring your own bosun's chair or climbing rig and go aloft?
#5 · (Edited)
I generally won't go aloft on a boat that I'm a complete stranger to, unless the rig is vouched for by someone I know and trust. :) Also, I doubt most owners would let you go up the rig given the liability issues if the rig should fail and you get injured. Finally, many boats are on the hard when up for sale, and going aloft on the hard is a really, really bad idea IMHO.
#7 ·
Here I thought I was dealing with a smart portagee, and in reality Gui's a SMART-ASS portagee. :)
Reactions: lumpy102
#8 ·
Excellent suggestions!
One thing I would key in on with the owner/broker is the boat's maintenance history. I'd want to know what had been serviced or replaced and when. I would not be shy about asking for repair receipts.
For example, I had all my standing rigging and chain plates replaced on my Hunter 30 in 2002. Should you just take my word on this, or should you verify my claim? Most owners would save these receipts. One of the reasons I decided to purchase my current boat was the fact the the engine had be recently overhauled and the owner showed me the repair receipts.
#10 ·
I carry a clipboard with a checklist and the other items mentioned.
#14 ·
Unfortunately most insurance companies require surveys from NAMS or SAMS accredited surveyors. I can obviously do my own, have worked with a close friend for years who is a very good surveyor, but I am not acredited by NAMS or SAMS so I still pay for them.
there is however absolutely NO need to be surprised by what a surveyor finds. You can also work out a cheaper deal to do an "insurance only" safetya and value survey if you are comfortable in what you've seen and inspected.
#15 ·
I would never forgo a surveyor, because I'm not a full-time one either, not to mention that insurers generally want proof of competence in the form of accreditation.
But as you say, if you do the "preface", you put the whole story in context or simply save a lot of time by identifying "deal breakers" early.
I drove 200 miles to see a boat once that it took 30 seconds to see had been T-boned and partially flooded. That was the last time I assumed a broker was anything but a lying whore.
I have since found a couple of truthful whore brokers, mind you...
#18 ·
Great post/thread. I'm sure many new buyers will find this very helful. A couple of issues that I think are worth touching on:
Was it used regularly or was it a dock queen? Not indicative of much of anything. A "dock queen" may be in more original condition and lightly used, but a regularly used boat that is well cared for may be better. I'd rather have one that has been used and all problems identified and fixed.
Did the owner have regular maintenance done to the boat? Owner may have done the maintenance themself. Just because someone paid for work to be done doesn't mean it was done right.
In this market you can't tell anything by this. The boat may have been over priced for a year before it was reduced. May have been listed with a bad broker, etc...
Or, it could be that the wood has expanded from 20+ years in a marine environment, etc...
Keep in mind that older boats especially are going to have problems. None are perfect. Some problems are bigger than others and some problems are big to one owner and not important to the next. It is good to identify problems and potential problems, but most all of them are repairable if you're willing to spend a few $$ and a few hours.
#24 ·
you guys with your surveyors are soo funny...
we here have none of that, really we don't....if you're dumb enough to get fooled by someone selling you a boat..your problem...most people that buy a sailboat, know minimally what they need to know to see if it's good or not...if they can't there is allways a friend that helps
here anyone buying a boat does their own "survey"..none of that stuff here...
Looks like stuff to protect you from you, by not having you do what you should do.....makes sense???
Imagine if to get my boat insured I neded to get a surveyor...ahaha that's funny...you guys are soo lazy...even need to hire a guy to look at a bota for you...
#30 ·
SD, Good info in your post as well as some of the follow-ups from others.
Giu, I actually agree with you to a point.
It wasn't too many years ago that sailors, at least the ones I knew, were in general a lot more competent and self sufficient than the average boater today. At least that's my observation.
There are probably a lot of very different reasons for this. Among them would be the development of the GPS system or the fact that there is a glut of cheap used small vessels.
Also, I think that insurance has help to make it easier for people to neglect their personal responsibility.
I see cases often where someone expects the insurance to pay for a new rig when the cause of failure was a 20+ year old chainplate or U-bolt that caused the dismasting. Even people that are in the marine industry, used their boat hard, should have known better and should have inspected and replaced the offending parts.
Anyway, there are a lot more people on the water these days and there is nothing necessarily wrong with that. Hell, it drives an industry. A lot of people make their livings based partly on the fact that anyone can just go buy a boat and go sailing in relative comfort and safety without having to go to the trouble of becoming sailors.
Boy, when I read that, it sounds harsh. I don't really mean it that way.:eek:
Sailing, Cruising, Boating, Yachting, whatever you want to call it, is a lot more obtainable than it used to be.
Technology has made learning how to do real navigation unnecessary. There are so many incredible products and services out there we don't really have to do much ourselves anymore.
EPIRBs and the Coast Guard are a pretty good backup plan if you stay close to shore, right? :(
I applaud SD's efforts to get people to stick their heads into those lockers and wiggle those shafts and to climb that rigging and knock on their hulls with little plastic hammers. And I would venture to guess that many of the participants here at Sailnet are pretty handy. But I fear that in general, the vast majority of boaters in the US would have a real hard time performing tasks that a boater 30 years ago would have considered basic.
#25 · (Edited)
Boat US did not require a survey on my J24 only good photos that showed the boat
And older J24 can be a real nightmare of core problems and for example if you look at one that has been frozen all winter things will seem to fine till it thaws out and the core turns back to mush
I think a survey is a good thing if you dont know were the warts are on boat brand X and does give a more objective look at the boat
The one thing i have nevr liked is that the survey person has nothing to lose if he misses something :rolleyes:
#27 ·
Great post SD, wish my son had it two weeks ago when he bought his first boat. Fortunately he found a great surveyor (Eberle?) in NC. I vote for this to be a sticky in Buying a Boat (do I get a vote here?).
John
#28 ·
Very nice !!
This is a wonderful set of tips. I am not in tghe market for a boat but have copied and saved this for future use. Maybe one day I will be looking and this might be handy.
#29 ·
A couple of points...
I didn't mention asking about the service receipts or getting an official survey done, since those are the steps after you decide you want the boat. This tip is pretty much written to deal with everything up to the point where you decide to push ahead and make an offer or not. :)
Yes, IMHO, you really need to get a survey. However, if you've done this part right, you should have at least a pretty good idea of what to expect on the survey.
#31 ·
Knotty-
True, many are far less skilled than those who were boating several decades ago... but if we hope for the masses to return to a shadow of those skilled sailors, we need to start someplace.
#32 ·
Speaking of surveys and to add to the list.
If a boat is interesting enough to you to do all this work, in advance of coming to the boat to begin with - have the owner's last survey sent to you. It can be used as a checklist - and furthermore you can use it with your surveyor (if boat passes your inspection) to verify that previous issues have been addressed. It'll also demonstrate the level of care the PO had with the boat.
#33 ·
Damm! I wish I had read all this 12 hours and 500 miles ago! A saw a winner today, and am making an offer in the morning, but all this would have helped a lot. HALF of this would have helped a lot!
Still, I did giver her a very good looking over - to the best of my ability, and of course the offer will be survey contingent.
