MacGregor 22 vs. Catalina 22 - SailNet Community
Blogs
Old 08-19-2002
lastmate is on a distinguished road
We''re looking for our first weekend lake sailer and have narrowed it down to an ''84 MacGregor 22 or an ''84 Catalina 22, both well-maintained. The MacGregor is much lighter--1800 lbs. vs. 2490 lbs, so easier to trailer and launch (draws only 6" with swingkeel up) but has built-in flotation--which does take away from interior space. We like the interior of the Catalina but it has no flotation and we''re wondering how it would sail in the light winds we get around here during summer (due to heavier weight), though Catalinas do seem to be very popular in this area. The Catalina would cost about $2,000 more but does have roller furling, a newer outboard, depth sounder, propane stove, sink, upgraded trailer, bimini, etc. and seems to have a higher base value--though it''s hard to find many MacGregors around of that era, most people don''t even realize there are steel-ballasted ones out there. The MacGregor has a lighted compass and knot meter (which the Catalina doesn''t have)and shade awning that can only be used while anchored. It has no stove and the slideout sink arrangement seems awkward and (though included) has been removed by the current owner since it seems to get in the way. Both boats have porta-potties and swim ladders. The MacGregor has a genoa, 110 jib and storm sail (which take up alot of room inside), while the Catalina only has the 110 jib on the roller-furling.
We would like decent performance but have a preschooler and are also concerned about safety and both my wife and I not having to both pay constant attention to the helm and sails. We''d mostly keep it docked at a local lake but would like to trailer it once or twice a year to Lake Erie, Kentucky Lake or somewhere else for a family trip. The Catalina is already docked at the lake we''d be using, and its owner will be continuing as a member of that sailing club, while the MacGregor is about 140 miles away on a trailer and was mostly sailed in Lake Erie till 2 yrs ago.
Any advice or recommendations are welcome. Thanks!
Old 08-19-2002
The Catalina is an ''87, not an ''84.
Old 08-19-2002
Sailormon6 will become famous soon enough
Either the C22 or the Mac22 will be easy to tow, set up and launch. My first small cruiser was a C22, and I once towed it to Michigan and back from southern Ohio with an old 6 cylinder Rambler.
Compare the weight and workmanship of the two boats and their hardware, and you will find the C22 to be stronger and somewhat better built.
The Catalina''s small jib will give you decent performance on a light-air inland lake, but I would suggest you negotiate with the seller for a price reduction of a few hundred dollars to help you buy a 130% or 150% jib. The 110% jib is o.k., but a larger jib will help in light air.
In 25 years of sailing, I have never known of either a C22 or a Mac22 that sank, although I''m sure it must have happened somewhere. Most small cruising boats don''t have flotation, because it occupies too much interior space that could be used for storage and other purposes, and because, in my opinion, it just isn''t crucial to safety if the occupants have pfd''s. Those boats are designed to be sailed in more protected waters, where you are close to shore at all times.
There is a MacGregor website, but it seems to be relatively inactive and of very limited usefulness to owners. There is also a Catalina 22 website, and it is extremely active, and loaded with thoughtful suggestions for repairs and upgrades, and information about where to obtain parts and supplies.
Most people buy a smaller boat at first, and after a year or two they move up to a bigger boat. So, regardless of which boat you buy, be careful that you don''t pay more than the current market value for it in your area, so you won''t take too much of a loss if you decide to move up.
The sailing club at my lake (Brookville Lake in southern Indiana) is very sociable, and organizes lots of family picnics, raft-ups, racing, winter banquets and other events, and the membership cost is really nominal. You will get much more out of sailing if you join your local club.
Old 05-15-2007
bambam is on a distinguished road
the Macgregor was built in Costa Mesa CA the Catalina was built in either the old Morgan plant in FLa or Woodland Hills CA. For day sailing both are fine boats but there are many diferences in the boats. Macgregor is lighter due to thin glass in the hull where the C22 has much more glass this is one of the reasons for the extra flotation in the Macgregor. the Catalina has more weight in the kell this means it will not heel as quick as the Macgregor but in light breezes the Macgregor will be quiker, it all comes down to what do you like if well maintained they are both good boats.
I have sailed both and am a present C27 owner and have sailed both many times on Newport Harbor I will admit I lke the feel of teh catlina more but this is up to you. I would sugest reying both find out what you like.
I do not know if Macgregor still builds the 22 but catalina has one of the best support systems of any manufacturer out there this could save on $$ and frustration. What ever you decide best of luck and enjoy.
Old 05-15-2007
Personally, I'd go with the Catalina... the roller furling makes using the genoa much simpler, especially if sailing short-handed. It is also quite likely to be the much better performing boat over a wide range of conditions. And finally, the larger interior is more toddler friendly IMHO. Finally, getting advice from the PO is going to be much simpler, since he's local to you.
Old 05-15-2007
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
SD - did you know this thread is 5 years old? (Couldn't resist that )
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
Music on the Wind -
Old 05-15-2007
damn.... guilty as charged... didn't check the dates.... but haven't had my coffee yet this morning. LOL
Taking a mental health day for the weather I see.
Old 05-15-2007
PBzeer's Avatar
Wandering Aimlessly
So far, may head out late this afternoon, depending on weather, and if I can get some sleep during the day. Could make Port Everglades sailing if the wind holds as predicted, by tomorrow afternoon. Then I won't have to deal with Miami.
John
Ontario 32 - Aria
JCP
Music on the Wind -
Old 05-15-2007
I'd rather sail in slightly windier and nastier conditions, than motor in really pleasant ones... I hate motoring...
Old 05-15-2007
camaraderie's Avatar
moderate?
PB...save the offshore for tomorrow! What's wrong with Miami?? Anchor off Coconuut Grove and enjoy the scene then go out the cut and up to Lauderdale on an easy sail.
catalina 30 new sails jhabaa1 Gear & Maintenance 2 02-15-2004 01:06 PM
Catalina 310 greatwhiteway Boat Review and Purchase Forum 10 07-02-2002 07:42 AM
Catalina 27 or 30 xavier6162 Racing 1 03-01-2002 05:24 PM
PHRF club racing a Catalina 27? Nawlinsguy Racing 2 12-09-2001 11:40 AM
A new catalina 36? paul-e Boat Review and Purchase Forum 32 09-21-2001 06:26 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
