01-28-2009
Misconseption
The SJ34 is a awesome boat; fast strong and reliable. There are a few differences than one persons history reports. The SJ34 never was foam cored on deck, it is balsa cored. Also she sails fine down wind untill you try to sail above hull speed. She was never designed as a modern plaining hull, once above hull speed she will build a bigger and bigger bow wave, unable to break ove, which acts as a sort of a break. This is fine if you understand it. She doesn't have a true roling problem asociated with IOR boat, because she wasn't built to capitolize on the IOR ruling. The problem lies in that just like a car which has no rear breaks, if you apply the breaks hard enough the back of the car/boat will try to rise up. The SJ 34 cannot break the bow wave, the harder it is pushed the further the stern will try to rise, once the point of diminished returns is reached it will begin to roll back and forth off the pivot point ( the bow ) untill it cannot be controled. The key is to keep her flat in the water or try to raise the bow ( which is vertually impossible ). The design is fine, she sails exactly as designed, points extremely well, sails down wind fine, is fairly fast and stable. She is not a true open ocean cruiser, a get wet extreme racer or a motor home on water. The SJ34 is a compromise of all with decent speed to please.
