11-03-2008
Doubleeboy-
A proper bottom peel and relaminate job is in the thousands of dollars... at a minimum.
To do it properly, they have to use a machine to plane away all the damaged laminate, and then dry the remaining hull out, usually using heat lamps and vacuum bagging, then they have to re-laminate the hull back to the original scantlings....and usually they re-gelcoat and then put a barrier coat over the gelcoat. Most owners aren't going to pay for that kind of work...since it can often be a significant fraction of the selling price.
