Old 08-25-2002
windship has a little shameless behaviour in the past
High ballast to displacement ratios
One of the boats I''m considering is an Endeavour 38. She has a fifty-fifty ballast to displacement ratio. (Here''s one for you Jeff)What''s the low-down on this?
Dennis
Old 08-25-2002
JeffH
Guest
Posts: n/a
I am not sure waht I think about that. 17,600 lbs is not that heavy for a 38 foot cruising boat. Achieving that kind of ballast ratio with proper structural design in a moderate weight cruiser is just not that easy. Stripped out racers like America''s Cup boats bearly achieve 50% ballast ratios. Even though the 38''s were cored I would be quite suspicious of that ratio.
Most cruising yachts have a ballast ratio in the 30% to 40% with many very respected cruising boats having ratios as low as a 30% or so. Even though Johann Valentijn, the designer of the 38 was a senior designer with Sparkman and Stephens and had worked on America''s Cup campaigns, I question whether even he could achieve proper structure, and adequate capacities with that kind of ballast ratio in a cruiser.
I saw that there is a couple 38''s on Yachtworld that do show 8600 lbs of ballast with a displacement of 17600 lbs. Obviously that is 49% ratio. While I am not sure that the 8600 lbs, (I have an piece of Endeavour literature that shows 7600 lbs ballast but I am not sure that it is for the 38 in question. 7600 lbs would result in a ratio of 43% which is still a pretty respectibly high ratio. That is in the range of heavily ballasted and pretty Spartan interior race boats of that era.)
All of that aside, if the 38 does have a 50% ratio it should be reasonably stable and offer a reasonable motion comfort. Both will be compromised a little by the shoal draft of the Endeavour 38. Endeavour used low density ballasts on their earlier boats but I do not know what type of ballast was used on the 38. With the 38''s very shallow draft of 4''-11" on a 38 footer a large ballast ratio, even if it is in low density ballast, would be very welcome.
My experience with Endeavours suggests that by the mid 1980''s the build quality of these boats had gotten substantially better as had the Valentijn and Kelly designed hulls and rigs.
That''s about it for me.
Old 08-25-2002
Jeff,
Thank you.
We share the same suspitions in regards to the build quality.
Thanks for the info on the designer. I didn''t know that.
I don''t think I would say her draft is ''very'' shallow.Mabey shallow but not to the extreme.
Thanx again,
Dennis
Old 08-26-2002
JeffH
Guest
Posts: n/a
I think that 5 feet of draft on a 38 footer, in the absense of a K/Cb or bulb, Scheel or wing keel, is a very shallow draft. Normally I think of a range of 5''6 to 6''0 being about the minimum for a good preforming, offshore capable, conventional keel 38 footer. Obviously these deeper drafts can be problematic in some venues such as the Florida West Coast where these boats originate.
Old 08-26-2002
JohnDrake is on a distinguished road
Hi Guys
Just got back from a wonderful weekend sailing my 38 footer. It has a true 50% ballast ratio and a 4''6" draft with a K/CB hull.
She is a Wauquiez Hood 38, a Ted Hood design, built by Wauquiez. I could not be happier with her performance and construction.
We had quite light air this weekend but she moved along surprisingly fast...of course not like a true light performance racer but much better than expected even in 3-4 knts apparent.
I can well attest to her motion comfort and sea kindly ride. These boat are said to be tender, but I have not observed that and when at 15 degrees heel, she locks in and goes for it. I am very pleased with how well balanced she is and her near phenominal ability to track well with the helm unattended. This latter point is a joy in cruising. When there is the need, the board is easily cranked down eliminating any side slippage at low speed and she can point to 30 degrees apparent wind even w/o the board.
Down below, she is very yacht like. Wonderful joinery and nicely laid out with a large Vee berth and ample aft quarter cabin.
I can see your attraction to the Endeavour. They have nice cabin layouts for weekending at the dock. My dock neighbor had a very difficult time selling his because of the wet hull coring. Practical Sailor has a review on them, but I will save you the trouble and just summarize by saying it was less than glowing.
I, however, am absolutely glowing over this boat.
My best to all, and thanks again to Jeff for his terrific advice.
John
Old 08-26-2002
Hi Guys
John
Old 08-26-2002
DuaneIsing is on a distinguished road
JohnDrake,
I sent you a SailNet message re your boat. Check there or email me at deising@aol.com
Thanks,
Duane
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
MacGregor 26 vs. ? jiml2p Boat Review and Purchase Forum 184 08-30-2011 08:10 PM
Encapsulated or Bolt On Keel? aasault Boat Review and Purchase Forum 34 06-19-2011 09:20 AM
What can you tell from the numbers? brazilnut Boat Review and Purchase Forum 10 07-01-2009 04:09 PM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 02:15 PM
