Old 11-08-2008
cords180 is on a distinguished road
Collapsible Mast
Hi,
I recently moved to a house in St Petersburg, Fl that has water access but you have to pass under a small bridge (8-9' at high/10-11' at low depending on the tide) so now I'm trying to find a nice daysailer or small weekender (used) manufactured with a collapsible mast. Other than Com Pac, are there other brands I can do searches for? Thanks
Cords
Old 11-08-2008
Not many boats that are going to fit under a 5' bridge that aren't going to be so small as to effectively not be a weekender. My boat has a mast raising system that allows you to drop the mast in about 15 minutes, but I doubt I'd be able to get it under a bridge with only 8' of clearance at low tide... I know it wouldn't make 5'.. You need to have a different location for your boat if you want a boat that you can weekend on IMHO.
Old 11-08-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
I thought these looked neat when they first came to market. Not sure how easy the mast is to raise and lower, but it sounds like it goes on like a laser or force 5.
Old 11-08-2008
Those are pretty neat boats...but would be tough to weekend in one.
Old 11-08-2008
sailboy21's Avatar
They got options
I used to weekend on my A-16 all the time. Its all a matter of perspective. I though "cruising" as a broke as dirt college kids was pretty cool.
Another boat I have actually spent a little time on is the Sea Perl. Very seaworthy and inovative sailing craft that might fit the bill.
Old 11-08-2008
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
You might look at the MacGregor 26' trailerable water ballast sailboat. They have a mast raising system that I have heard decent things about. I would not get the newer 26X or M model though. Look for the 26 S or D (none of the older boats sport a 50HP outboard engine). There was a 26X in our mooring field whose mast broke at the spreaders this season.
Barring a boat this big I would suggest a Sunfish or Laser that you could pull the rig down for getting under the bridge. If you can deal with a trailerable boat then find a launching ramp beyond the bridge.
Good luck.
Old 11-09-2008
I don't know if the mast raising system on the 26S or 26D will still allow the boat to pass under that bridge at high tide. They could probably make it at low tide... but 5' is pretty tight clearance wise.
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
Southern Cross 31? db27513 Boat Review and Purchase Forum 35 09-24-2007 10:58 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
