small pocket cruiser with shallow draft and low freeboard - Page 2 - SailNet Community
post #11 of 19 Old 02-21-2009
gaha_1's Avatar
is that 7' at high tide
gaha_1 is offline
post #12 of 19 Old 02-23-2009 Thread Starter
the 7' is what is marked on the noaa map...
FREDDYFUNKALICIOUS is offline
post #13 of 19 Old 02-23-2009 Thread Starter
the red x is soon to be my house
post #14 of 19 Old 02-23-2009 Thread Starter
i really like the catboats... that is looking like a good option. now i just need to find a cheap one on craigslist
post #15 of 19 Old 02-24-2009
Selkirk's Avatar
There are usually a bunch of Marshall Sanderlings around.
They're 18 footers.
When you come to a "Y" in the road, take it....Yogi Berra
Selkirk is offline
post #16 of 19 Old 02-25-2009
SHays's Avatar
I was researching pocket cruisers here a while back. I think the Compac Legacy would be a sweet option for you, and you could certainly raise the mast after ducking the bridge... full length keel, and board to lower after the fact and a cozy cabin. Stable little craft, but pricey... The Sanibel 18 would be hard to beat as well. A little more sleeping room below on the Sanibel, and slightly more beachable than the compac. There are some great mast raising tools that come with the mcgregors, but I had bad experience with the 26s model, and its ability to "point." I think I would go for the Sanibel in that situation...
Steven
SHays is offline
post #17 of 19 Old 02-28-2009 Thread Starter
Thanks for all the advice.
The com-pac suncat looks great. It seems like a really easy boat to rig. BUT There are not many used ones in my price range 2-4k. Are there any other <20' pocket cruisers with masts that easy and fast to rig? Can they be rigged while afloat?
post #18 of 19 Old 02-28-2009
Nordica 20! I promise you will love this boat, it is a 20 foot double ender. Best 20 foot boat ever! I love these boats for the stability and quality of larger boats but in a tiny package.
I can't post websites yet but just google 'Nordica 20 sailboat'
J24mark is offline
post #19 of 19 Old 03-18-2009 Thread Starter
got my boat!
Well, after weeks of looking I ended up going with an '88 compac 16. I took her out for her 'maiden voyage' on saturday and she was a fine sailor with a roomy cockpit, hardly any draft, and a mast that's light as a feather! I couldn't be more pleased...
well, there was one problem...
the bow eye (ubolt) is loose in it's seating (rotten wood block) and a small trickle of water is getting aboard! I assume I need to remove the rotting wood block and replace it, however, does anyone know how I should go about sealing it afterward?
This should probably be another post huh? I will post in the "Gear and Maintenance" Section under the title "compac 16 bow eye loose... rotten wood?"
James Baldwin's Pocket Bluewater Cruising Boat List sailingdog Cruising & Liveaboard Forum 14 09-16-2011 06:26 PM
