03-10-2009
Originally Posted by JohnRPollard
What did you say?
Cruisingmom, as you can see we like to kid around quite a bit here, so don't take Boatpoker's comments as anything other than a little kidding.
Boatpoker posted the note above about the balsa coring extending to within 15" of the hull centerline, which would put it well below the waterline. You should mention this info to your surveyor, and you should be able to find evidence of this when you inspect the inside of the hull during survey.
Good luck and, please, consider giving us an update after the survey is completed. We're curious too.
Many many thanks for your wise input, John. I copied your info for the surveyor as well. Just want to gather as much information as possible before making the decision. We have looked at alot of Whitbys, but this is our first survey. In fact, we looked at a Pearson 39 , which the owner claimed was not balsa cored below the waterline, and we were able to find evidence to the contrary all by ourselves.thanks again will keep you posted
