03-23-2009
While you can get a pretty steep discount on a former charter boat, I wouldn't recommend buying a boat that way. Most charter boats are in significantly worse shape and have significantly more abuse and use than a privately owned boat of the same age. Also, many times, the equipment on a charter boat is the minimum that you'd want on a boat that size and generally needs to be upgraded a bit for personal use. Finally, the cabin layout and such is often optimized for the charter business, and not as well suited to personal ownership. For instance, many will have a three cabin layout, with two aft cabins that are relatively small compared to the non-charter version of the boat which has a single, much more spacious aft cabin instead.
