Pearson Triton - Page 2 - SailNet Community
post #11 of 19 Old 07-26-2009
mitiempo's Avatar
As far as I know all Tritons and virtually all sailboats built in the last 30 or so years have a cored deck. The reason is that without a core of some kind the deck isn't stiff enough. A friend lives on his Spencer 35 and his deck is not cored though plenty strong enough. When you walk on his foredeck there is a bit of spring to it - coring eliminates this. The MK 2 version of this boat used core. Whatever boat you decide on check the deck for sponginess that indicates water intrusion into the core. After you find one that you like and have checked out to the best of your ability have it surveyed. If you would like to read more about recoring and Tritons as well as other boats see this link: The Plastic Classic Forum • Index page
Virtually everybody on this site is recoring or modifying their boat in some way.
Brian
mitiempo is offline
post #12 of 19 Old 07-26-2009
Mud Hen #69, Mad Hatter
Delirious's Avatar
Cored decks and hulls have enough advantages that they were and are used. Stiffness, weight, elimination of condensation. Cored decks and hulls can be stronger than non. Just as your bones have a mushy marrow - a hollow tube is stiffer and resists bending more than a solid one . . . of the same weight.
I would not pass or fail any design just because it used a balsa cored deck. Have it surveyed. Very possible some prior owner(s) corrected any problem areas or routine maintenance has allowed the balsa to remain stiff and dry without needing a correction.
Triton #1 is on the same lake as us and undergoing restoration. The deck fittings are being rebedded but, as far as I know, the original core is in place. I can check if you like.
Our Pearson 31-2 had some balsa deck issues that were corrected and it passed the survey I had done before buying her. Required digging out some balsa and replacing it with filled epoxy. Don't assume balsa is a disease.
Charlie P. Mud Hen 17 #69 Mad Hatter
To travel hopefully is a better thing than to arrive - R.L. Stevenson
I suspect that, if you should go to the end of the world, you would find somebody there going farther . . . - H.D. Thoreau
Delirious is offline
post #13 of 19 Old 07-27-2009
Here .. Pull this
FWIW I spent a lot of time cruising on a small schooner that would make a Triton seem luxurious. I was a lot younger then and my priorities were different. If the boat is solid then you can add things as you go. There is no shortage of people who are happy to sell you anything you might think you'd like.
These days I'd call anyone who did what I did then a complete idiot with no sense, or regard for personal safety, but you know what ? I survived and so are thousands of others who are out there right now being just as foolhardy.
The west coast Tritons were built with solid decks.
Cores rot. Decks, Hulls, whatevers...if/when they get wet the balsa rots. There are undeniable advantages to using a core, and you're hardpressed to find a boat that doesn't have some type of core somewhere, but they will degrade over time.
Good Luck
Sailormann is offline
post #14 of 19 Old 09-11-2009
Love the Tritons. I sail with a group of Tritons out of Annapolis. I myself have two of them - both "free" boats I have yet to sail on. They are beautiful, seaworthy boats with a great motion. I have heard some complain about the weather helm, however, I have crewed on boat's whose skippers knew how to trim them to neutral helm. I have heard people who prefer the west coast decks due to no maintenance. The cored decks are a little more solid so I've been told, as long as they're properly maintained.
Good luck in your choice.
Matt
mhoughton is offline
post #15 of 19 Old 09-12-2009
Just for the record...
The Bristol 32 is solid fiberglass, no wood cores, and the decks are solid as concrete floors.
seabreeze_97 is offline
post #16 of 19 Old 01-02-2016
Re: Pearson Triton
I own #405 and doing a refit for extensive travel in 2017 , solid as a rock , responsive and when I walk away from the slip she turns my head every time
Yes she is not a racehorse but a draft horse and out there I prefer that ( transom solid fibreglas thickness 1"1/4 you can split rocks with that boat and if you start to travel you will hit objects floating and below surface
Other than a larger lazarett the alberg 30 is the same boat ( not as pretty a transom however on the alberg)
I installed an outboard well also with the help of James Baldwin ( Atom voyages ) and got rid of the stinky greasy bilge , now it's pleasant down below and it's easy to repair or change an outboard
Good luck with whatever you get it's wonderful being out there , Harald
Calciumsilicate@icloud.co is offline
post #17 of 19 Old 01-02-2016
I don't discuss my member
Fstbttms's Avatar
Re: Pearson Triton
Originally Posted by Calciumsilicate@icloud.co View Post
Good luck with whatever you get...
Not that it's important or anything- but yours was the first post in this thread since 2009. The OP hasn't checked in to this forum in a year and a half.
Fstbttms is offline
post #18 of 19 Old 01-03-2016
it's a long story
turboduck's Avatar
Re: Pearson Triton
Given that this is an old thread, there may still be folks shopping for Tritons. Add Columbia 29s and Defenders to the search. My 53 year old hull #37 has no hull, rudder or deck issues; and doesn't leak anywhere. I am rebuilding the mast support, and she needs a paint job, otherwise she's still ready to get back out there. And, if I may be so bold, sails a little better than a Triton. Sorry she's not for sale.
Don
1962 Columbia 29 hull #37
turboduck is offline
post #19 of 19 Old 01-03-2016
mitiempo's Avatar
Re: Pearson Triton
It may be an old thread but members rarely look at old threads. Start a new thread.
Brian
mitiempo is offline
new pearson owner firemanbob General Discussion (sailing related) 16 02-28-2011 11:34 PM
Going loco? Pearson 30 vs. Capri 30, Olsen 25 uniexpany Boat Review and Purchase Forum 5 04-11-2006 11:09 PM
Tartan 31 or Pearson 31-2 Fishboat Boat Review and Purchase Forum 1 04-25-2004 01:11 PM
Great Lakes Pearson Rendezvous sailnuts General Discussion (sailing related) 0 03-30-2004 08:02 AM
Spinnaker on Pearson 30 zeilfanaat Gear & Maintenance 4 07-22-2003 04:42 PM
