I was looking at a mid-80's vintage CAL 33 the other day. The broker said it had a cored hull. I couldn't peer into most of the lockers, but I could not find any evidience in the lockers that I did look into that it was... Does any one know if CAL used solid or cored hulls?
The broker discolsed that the boat had some minor "crazing" that all CALs seemed to have. "It is merely cosmetic" the broker assured me
The day was clear and dry, so I puled out my moisture meter, and found a few small wet (30%) spots, and a couple of damp (15%) spots. Most of the deck was fine, but there were some cracks that disturbed me. I would like to get some opinions from the good folks in the forum:
If you look closely, you can see that there are cracks in the coachroof from the clutches to the cabin side. I suspect that the clutches were not installed properly, and need to be remounted with proper backing. This area measured 15% on the meter.
These cracks along the stbd toe rail showed about 20% moisture... I know that the chainplate on this side needs to be rebedded. The Chainplate registered 30%.
Finally, these cracks near the anchor locker... Again, elevated moisture, but not what I would call "wet."
I understand that I will need to get a surveyor before I get serious. All comments will be taken with a grain of salt, and you're all off the hook in terms of liability.
However, I've been looking at boats for the past 2+ years.
EVERY boat that I have inspected (and there have been over a dozen) has had moisture in the decks
. This is the first boat that I've considered having surveyed.
All comments appreciated!
