05-04-2009
Umm... I think you're confused or posting in the wrong thread... Mimsy and her ARE are looking at a 42' boat IIRC, a Tattosh 42.
Originally Posted by scottyt
from what i have seen if you get a rigger to make each shroud or stay with a swag fitting on one end, and a staylock or what what ever swagless you want on the bottom end, then install them yourself you are looking at an average of 100 per wire for a 27 footer. basicly it means you will be going up the mast 4 or 5 times thou.
basicly, you go up the mast, remove the back stay, attach the new one, come down cut it to length and attach. go back up do the fore stay the same way. go back up do the shrouds etc etc. make sure you support the mast with a halyard while you remove each one. this might take you 2 days unless you can get up the mast with out tiring you or the wincher running you up.
another option is to rent a cherry picker, then doing them in one day is easy, because you can now do 2 each trip up because there is no person swinging around up there. if you do the cherry picker method try talking to others at the marina, you might get them to pay some of the price for things like anchor light bulb change outs
