CHEAP J/24....any thoughs? - Page 3 - SailNet Community
post #21 of 26 Old 05-15-2009
Partially hydrated Member
Smile J/24 decision
You should go back to school for more learning IF you still waste the time and money on even seeing this wreck of a J/24. After all the experienced sailors online have remarked on the worthless condition of your prospective boat? Why would you even waste the time to travel 300 miles to inspect it?
They have all counseled you with honesty and compassion. You will undoubtedly make many more bad decisions in your future life. Don't ad the purchase of this lousy sailboat be another bad decision. Heed the advice of more learned sailors than yourself.
You will be glad you disregard this boat. It is your decision and yours alone. Let's see if college has placed any knowledge into your cranium. Think first about having it now versus waiting to find a better deal on a good J/24.
Good luck in your decision.
sanjuan2R is offline
post #22 of 26 Old 05-15-2009
celenoglu's Avatar
If you want the boat for sailing forget this one. If you want the boat to work in your garden, buy this one. You will be able to learn how to repair a boat (do not forget to make a list of your expenditures).
A "cosmetic" osmosis is osmosis. The boat will start to disentigrate very soon.
celenoglu is offline
post #23 of 26 Old 05-16-2009
Here .. Pull this
I'll break it down for you:
a) If you don't have the money to get on a plane or rent a car to go look at this boat you can't afford the boat. Not only can you not afford this boat - you can't afford any boat right now.
b) If you buy that boat it will cost you an absolute minimum of ten thousand dollars to make it seaworthy - and probably over twenty.
c) Once the boat IS seaworthy (if ever), you need at least a couple of thousand a year to keep it floating.
d) If you save the money that you have now for another year or two and add to it, you will be able to buy a boat that is worth owning.
Sailormann is offline
post #24 of 26 Old 05-16-2009
tommays's Avatar
Well
As Cardiacpaul said 10k is chump change and i am going at getting it right at a slow pace
1981 J24
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #25 of 26 Old 07-14-2009
thanks
these are all great posts! ....well said and have stopped me from doing something dumb also!
mrkeith is offline
post #26 of 26 Old 07-14-2009
RUN from tis boat!!!!!!!!!!!!!!!!!!!!!!!
7Psych is offline
