Old 05-05-2009
swimnfit's Avatar
swimnfit is on a distinguished road
Question Power washing Interior
Hi everybody.
I am interested in looking at a particular boat (Catalina 30) from a local broker. The boat looks great inside and out. However, the Broker in the first description of the boat states, and I qoute: "The entire boats interior was emptied and power-washed and bleach cleaned in 2005".
I have never heard of this being done. Has anyone else had experience with a power washed interior? Should I be worried and let this boat go? Or is this normal. Once again, any sage advise is greatly appreciated
“A wet sheet and a flowing sea, / A wind that follows fast / And fills the white and rustling sail / And bends the gallant mast.”
Old 05-05-2009
Unless there was a really serious problem with mold or something else, like the boat being sunk... there should be very little reason to do this... If the boat was sunk or had that serious a mold/mildew problem, it's probably got a lot of other issues that are more than cosmetic.
Old 05-05-2009
tommays's Avatar
That just cant be good
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 05-05-2009
djodenda's Avatar
djodenda will become famous soon enough djodenda will become famous soon enough
Meh..
I've (gently) power-washed the interior of a Catalina 22 and a Columbia 26. I've found it a quick way to get the general grime out of a boat. It's a pain to remove the cushions, etc before doing so, but it's pretty easy once you get started.
I've always been careful to stay away from the electrical, and make sure I dry things off when I'm done...
Of course, as you are suspecting, it may mean that the boat was really trashed at some time, which would raise other potential issues.
David
David
1987 CS 36 Merlin "Kyrie"
Old 05-05-2009
mgmhead's Avatar
Somewhat Senior Member
mgmhead is on a distinguished road
Maybe it was just to remove the blood stains. No biggee!
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
Old 05-05-2009
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
I did it to my own boat when I bought it. Of course I pulled all the electrical, and there wasn't much on the boat to begin with.
Merit 25 # 764 "Audrey"
Old 05-05-2009
WouldaShoulda's Avatar
AEOLUS II
WouldaShoulda is on a distinguished road
TV commercial:
Car ad, "slight smoke damage" strike that "new upholstery!!"
Old 05-05-2009
swimnfit's Avatar
Thank you everyone. Some of those ideas I had not thought of (Sinking and mold). Others however... crime scene cleanup and smoke damage were unfortunately the first to come to my mind. If I decide to look at the boat I will inquire as to the reason for power washing the interior and I will defintely keep a keen eye at the electrical.
Old 05-05-2009
I'd also recommend you read the Boat Inspection Trip Tips thread I started, as it will help you determine whether the boat is worth going further with or walking away from.
Adding shore power to 1969 Cal 29 themcnasty Cal 0 06-19-2008 03:42 PM
The Amazing Power of Water Generators Kevin Jeffrey Gear and Maintenance Articles 0 06-16-2003 08:00 PM
Charging with Wind Power Kevin Jeffrey Cruising Articles 0 04-21-2003 08:00 PM
Dockside Power Tom Wood Gear and Maintenance Articles 0 02-07-2002 07:00 PM
Adapting Power Sue & Larry Gear and Maintenance Articles 0 12-20-2001 07:00 PM
