Bayfield 32C versus Aloha 32 on Lake Ontario - Page 3 - SailNet Community
Blogs
  #21 (permalink)
Old 05-21-2009
Here .. Pull this
Sailormann will become famous soon enough
For Lake Ontario I would recommend a CS 30/Express 30/Aloha 30/C&C 30 in that order. All of them can be had for $40K the latter three for less than 40.
They all sail nicely and will hold their value if you maintain them.
Of the four, none of them are ideal seaboats. You might be okay on the C&C 30 but the rest of the boats have rather flat bottoms for offshore sailing.
The issue is that the winds here in the northen climes and particularly on the Great Lakes tend to be lighter than those farther south, so what sails nicely here can get overpowered down there.
I really think you should focus on getting something suitable for the Great Lakes and I am strongly biased to the CS30 (I have one), as it's a very well-built boat with great performance and a nice roomy interior.
They are usually equipped with everything you need: refrigeration, propane stoves, hot and cold pressure water and decent shore-power wiring. Most of them have been barrier-coated already and there is a very active online owner's group.
The C&C 30 is also a great boat and will probably run about 10K less than the CS30. Not quite as much room inside and they are a tad slower but still great boats. There are more of them than there are CS30's.
Not sure if you have seen this site or not but it's good information for the Lake Ontario region. (Note that the estimated values are not too accurate - the site has not been updated for a while.)
Sailboats in Canada - 27' to 30' models
  #22 (permalink)
Old 05-21-2009
zAr zAr is offline
zAr is on a distinguished road
I'm following up on that! The first boat I wanted was a CS36T and I'm very impressed with the CS'es in general. I also like the CS30 quarterberth and decent headroom (I'm 6'2"). The Aloha would be a nice boat but I know the manual and documentation is nowhere near as good as the CS and the Aloha community seems small and inactive, in comparison.
I just sent out a bunch of inquiries to look at CS30's. Thanks for that.
Lake Erie to Lake Ontario AjariBonten Cruising & Liveaboard Forum 14 02-22-2010 08:55 PM
Sandbanks, Lake Ontario py26129 Cruising & Liveaboard Forum 4 01-07-2009 03:35 PM
Lake Ontario vs Lake Michigan Irwin32 General Discussion (sailing related) 14 03-19-2008 07:21 AM
Lake Ontario to Florida, Keys & caribbean amunk Cruising & Liveaboard Forum 8 06-02-2005 07:34 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
