S&S 39 Sailing Characteristics - Page 2 - SailNet Community
post #11 of 12 Old 05-25-2009 Thread Starter
Ilenart's Avatar
Originally Posted by KeelHaulin View Post
The hull plans are very similar to my C&C designed Newport 41; late CCA era hull with high aspect IOR style rig, with graceful overhangs and a non-planing hull. Should sail well aside from being a bit underpowered sailing downwind with the smaller area on the mainsail; but the easily driven hull helps make up for it (with respect to heavier displacement cruisers). We tend to do better sailing DDW than at 160 deg because the main blankets the jib; yet does not drive the boat well enough alone. At 120deg she picks up good speed but if your destination is DDW you might as well run wing and wing.
Upwind performance on my boat is very good; tracks well, tacks in ~80 degrees. In light wind it will have difficulty pointing but that's true of all but the lightest (ULDB) race boats. This hull design is a bit tender but once you get a handle on sailing with flattened sails it is easy to pinch up a bit to reduce heel in a gust. We regularly sail in 25-30 kts without reefing; I think my SA/D, ballast ratio, draft, and beam, are pretty close to the S&S 39 also.
Thanks Keelhaulin, thats exactly the type of info I was after.
Ilenart
Ilenart is offline
post #12 of 12 Old 05-28-2009
Sailing Junkie
ehmanta's Avatar
Ilenart,
I have a S&S designed Tartan 37 which is of the mid 70's design era and I would think behave similar to the S&S 39, although the 39 may be closer to a S&S Swan. My Tartan is great on all points of sail, though could be better downwind, but not bad....fingertip steering. She settles in at around 20 degrees of heel and just stays put like a dog with a bone!!! I have a centerboard, but I don't think there is a lot of difference with the deep fin version. I do not think you could go wrong with the 39 if you love to sail, because most ALL of the S&S boats know how to sail
ehmanta is offline
CREW/PARTNERS WANTED Bluewater Sailing the World Classic S&S jandy Crew Wanted/Available 5 03-21-2009 04:47 PM
Cruising Multihull Sail Trim Kevin Jeffrey Buying a Boat Articles 0 10-05-2004 08:00 PM
Sailing Basics Steve Colgate Her Sailnet Articles 0 03-09-2003 07:00 PM
