Old 06-15-2009
Reforming Stinkpotter
captainjay is on a distinguished road
8 Hours with the Surveyor Today Issues Erricson E39
So I spent a solid 8 hour day with the surveyor today. A good six of them on the boat. So someone either talk me in or out of this thing.
Things that I was pretty sure needed attention (now I know they do):
Major Cleaning, Buffing & Waxing.
Running and Standing Rigging.
12 Volt Electrical Panel (original toggle switches).
110 Electrical Panel (crazy square D home panel a few outlets and a shore charger as well as a dead or about to be dead 110 fridge)
there is a separate 12 Volt fridge unit that is only 6 years old.
Bimini needs re sewn and new zippers.
Mainsail cover needs a few patches and new snaps around the mast.
Cables on steering quadrant need replaced.
Bottom needs done. Haul clean and paint last bottom job 2004 prior owner. I have seen pictures and it looked good then.
Log on the shaft needs replaced.
Kitchen counter and sink and faucet and stove look like *#(^$
Things I thought would be a problem and are:
The mast step is done, it is severely corroded and basically unsafe
The crazy steel cross members under the forward and aft bulkheads are corroded as well, the aft one is much worse than the forward one the flange on the hull bottom were it bolts to the keel is toast
The forward one will clean up and survive a while longer
Things I didn't catch the first time out:
The water tanks under the floor are weeping so they aren't long for this world
Every through hull is suspect this is unfortunate as they aren't as old as the boat but have had no maintenance over the last four or five years and most won't close ( have to write them off)
The one that really makes me mad, The two forward bulkheads have serious damage, both inner chain plates that attach to the bulkheads have been leaking for a while and there is rot on both sides. There is evidence of a former repair on the port side and serious delamination under the settee were the aforementioned metal cross member bolts through.
The bulkhead repair will require removing both settee's and laminating a new bulkhead (1/2 teak plywood over the old then retrimming it all out with new bolts for the chain plates)
I won't go into the various lights and switches and other little everyday BS that is wrong with the boat.
The good stuff:
A six year old motor that is in good shape.
A boat that sails well.
Serviceable main sail, and jib as well as a nearly new spinnaker.
The boat had the shaft, prop and cutlass bearing replaced in 2002.
It also had and additional 20 or so grand spent on it between 2001 and 2002 by the owner before last. I have gone through the receipts and with the exception of the motor and refrigeration most of that good will has been used up.
So here is were I am with the boat and the budget:
The boat is $18000.
It will likely cost $3000 to $4000 to do the rig.(including the new step).
It will cost me $3000 to do the bottom.
It will cost me $2000 to do the running rigging. (Lines blocks, Traveler)
It will cost me $1000 in materials and a lot of my time to do the repairs to the bulkheads and reconfigure the salon berths the right way, and refinish the interior.
It will cost me $1000 in material and a lot of my time to fix the electrical panels.
It will cost me $300 to replace the head and straighten out the plumbing there.
Steering quad will cost $500 in materials and my time.
Canvas repair $500
Shaft log $500 including labor to replace.
Through hulls $500 and my time.
Materials for counter, sink and faucets $500
New lights fans etc $500
Stove $1500
Water Tanks, steel cross members and floor repair?
Does the fiberglass liner under the floor provide any serious structure or can this be reconfigured?
Just because someone will ask. My skills include, fiberglass and gell coat repairs as well as lots of west system work.
I used to be a general contractor and finish carpenter in a former life. So the wood work doesn't scare me. I also have wired whole house and I have don't some pretty extensive wiring work on boats as well. I also work in the charter business and have good contacts for the things I can't handle.
So is the boat worth it the money and the time or should I move on? My guess is that I will end up north of $30000 and closer to $40000 with the repairs and that is before we get into wish lists and might as wells. Like solar panels and stereos and plotter oh my.
Jay
PS here is a link to the pictures for anyone that didn't see them in the other thread.
Old 06-15-2009
nk235's Avatar
nk235 is on a distinguished road
Unfortunatly I don't think anyone can really answer this big question for you as everyone buys a boat for different reasons. As an example when I was looking two years ago I went through about 200 boats before I bought mine and I did buy it because it was turn key with over $20k invested in it by a meticulous previous owner so I didn't really have to do a thing. On the other hand a good friend of mine bought his boat for 1/3 the usual cost but then spent a year and close to $25k doing tons of work to it just like you would have to do on yours. He likes doing the work though and it is part of the reason why he bought the boat where as for myself I would not like doing all that and would prefer to pass and look for a boat with minimal work as I did.
So what I am trying to say is as long as you know what is invlolved with fixing her up and especially with the costs, then ask yourself is that something you want and are prepared to do. Otherwise if it is not pass on this one and I am sure you will find another. There is no wrong or right answer but only the answer that will suite you best and make you most happy. Goodluck!
Morgan 323
Old 06-15-2009
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
Too many things wrong with that one. I'd pass.
Old 06-15-2009
k1vsk will become famous soon enough
It always takes more time and money than you think. For that price, there are a lot of boats which require minimal work and/or upgrades, all for the price you have already budgeted for purchase and repairs. Would you rather sail or work?
Old 06-15-2009
topograph is on a distinguished road
Originally Posted by nk235 View Post
... is as long as you know what is involved with fixing her up and especially with the costs, then ask yourself is that something you want and are prepared to do. Otherwise if it is not pass on this one and I am sure you will find another. There is no wrong or right answer but only the answer that will suit you best and make you most happy....
As long as you can sail her while you fix her up, a project boat can be fun and fulfilling. I just wouldn't buy a boat that I can't even sail until I put a fortune in her.
Old 06-15-2009
redcobra's Avatar
redcobra is on a distinguished road
How much do you love the boat?
I found a Pearson 39 Yawl that called to me. It was rough but with a sound hull and deck. I bought it for about $15k. I put $60k into it. Some say I am crazy, but I have a boat that is like new with everything upgraded or replaced except the hull and deck. Rigging, sails, interior cushions, winches, etc. etc. etc. New engine too.
Could I get my money out of it. NO.
Do I care. NO!
How much do you love THAT boat?
Old 06-15-2009
Here .. Pull this
Sailormann will become famous soon enough
I think your repair estimate is about half of what you would actually end up spending. When you look at everything on your lists - there is not much on the boat that doesn't need to be replaced/repaired. You need to determine if the boat is worth 100K to you.
Old 06-16-2009
Well after a good nights sleep and thoughts of what a task the boat would be. I am leaning toward not doing it. I will have the printed survey tomorrow with better pictures. I do like the work, that said I do it every day for a living so I don't know how long it would continue to be fun. When I first looked at this boat I thought it would be possible to do some minor repairs to the bulkheads, replace the questionable rigging, tighten up a few odds and ends and sail the boat, knowing that I would have other projects down the road. The mast step and other structural issues weren't on my radar. I also knew that I would have to address the electrical issues as well. In all likely hood someone could do some patching up and live on the boat here and sail once in while but I am just not wired that way. If I can't make the boat right I won't be happy.
Frankly living here does complicate things as well, as yard work and lay days are very expensive here. I do have good sources for parts being in the industry but freight adds to the cost of parts as well.
I do appreciate all of the frank and honest responses.
Jay
Old 06-16-2009
Here .. Pull this
I think you have made a wise decision. Keep looking - there are lots of great boats out there !
Old 06-18-2009
Well I have officially backed out of the deal. I am out about $800 with the survey and a couple of trips to St John. I did agree to pay for a couple of ads for the seller out of my deposit and expect to get the other four hundred back today. I did make him a counter offer of $8000 based on the report figuring I could get the structural work done for $10000 locally and then I would have been back were I started. He wasn't interested. So we are shoping again.
Jay
The Art and Science of Standing Watch John Rousmaniere Seamanship Articles 0 02-08-2004 07:00 PM
The Art and Science of Standing Watch John Rousmaniere Cruising Articles 0 02-08-2004 07:00 PM
The Art and Science of Standing Watch John Rousmaniere Racing Articles 0 02-08-2004 07:00 PM
The Art and Science of Standing Watch John Rousmaniere Her Sailnet Articles 0 02-08-2004 07:00 PM
