Minimum Boat Preparation Time? (going offshore) - Page 2 - SailNet Community
post #11 of 17 Old 09-11-2009
AdamLein's Avatar
Okay can somebody please explain polishing the fuel for us neophytes with our little gas outboards?
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #12 of 17 Old 09-11-2009
Zanshin's Avatar
Diesel fuel tanks, over time, can collect significant hard deposits as sludge at the bottom of the tank. Additionally, it is possible to get growth in diesel which also adds nonsoluble sediment to the fuel. In heavy weather the sludge can get shaken loose from the bottom and very quickly clog fuel filters and thus stop the engine.
"Polishing fuel" is a method to force circulate the fuel through a set of filters to remove all of these solids before they can cause damage. There are several systems out there but they all do the same thing - filter the fuel (usually repeatedly) outside of the normal tank-to-engine loop.
Zanshin is offline
post #13 of 17 Old 09-11-2009 Thread Starter
***** newbie
Hi All,
Thanks a lot for the advice to everyone who's replied. I've picked up some very helpful direction thank you.
I was starting to think I was crazy for allowing less than 3 months, but it sounds like with determination, picking the right boat and a good surveyor, a fair bit of cash (and luck) our plans should be do-able! I'll certainly be allowing as much time as possible, but its good to know a rough cut-off.
Cheers!
RMCA
RMCA is offline
post #14 of 17 Old 09-11-2009
Sailing Junkie
ehmanta's Avatar
OK,
Here's my thoughts on your situation: First off, great boat for the money! (I'm a little biased!!) The T-37 only has 90 gallons of water, so you will need to either add another tank, or go with a watermaker. Obviously, you can get by without for a while, but this is something you'll need to consider. We go through our tanks in about 5 days, but we aren't conserving much since we are only out for a couple of weeks at a time. Upgrades to the Tartan that you'll need may include the standing rigging, autopilot or windvane, radar, maybe new instruments, check or replace the steering cables, check the rudder for it is prone to water intrusion (there is a discussion of this on the tartan 37 website). Check the centerboard and its' hinge assembly...the hinge and associated bolts can develop crevice corrosion. The plastic Beckson portlights may need upgrading. I went with stainless ports and it really dressed up the boat.....made it look like a brand new Tartan!
I love our Tartan, she sails beautifully with a balanced helm and goes well on all points of sail except she's a bit slow on a dead run, but a lot of boats suffer on that point, just crack off a few degrees and all is well.
If you need a good sailmaker in the mid-atlantic, I know the place......they delivered my new main within two weeks and it is a work of art!
Hope this helps, Tom
ehmanta is offline
post #15 of 17 Old 09-11-2009 Thread Starter
***** newbie
Thanks Tom, great stuff. A Tartan is at the top of our shortlist. If we end up buying one I'll definitely take your points on board. Cheers, Rob
RMCA is offline
post #16 of 17 Old 09-11-2009
Moderator
JohnRPollard's Avatar
Originally Posted by RMCA View Post
Hi All,
Cheers!
RMCA
RMCA,
Another factor will be where you undertake the refit. Some locations have better/ready services than others. You mentioned Florida, but may I also suggest the Annapolis/Chesapeake region for the boat purchase and refit? Lots of inventory in this area, and plenty of competent marine services too. For the crossing, you can jump out to Bermuda from the mouth of the Chesapeake and continue on from there....
Originally Posted by ehmanta View Post
....If you need a good sailmaker in the mid-atlantic, I know the place......they delivered my new main within two weeks and it is a work of art!
Tom, All good info. Would you be willing to drop your sailmaker's name here in the thread, so others can benefit from the recommendation?
JohnRPollard is offline
post #17 of 17 Old 09-11-2009
Sailing Junkie
ehmanta's Avatar
John
I wasn't sure if it was cool to plug a business, but since you asked.....
I used Ullman Sails in Deltaville, Va. Jerry Latell is the owner there and is real easy going and knowledgable. Quick delivery! I had them build an offshore quality main sail that turned out real nice and was every bit as nice as the Hood main that it was replacing. They also converted over my jibs for roller furling in the past.
Tom
ehmanta is offline
is the Carribean coastal sailing or offshore? troyaux Boat Review and Purchase Forum 40 02-24-2010 12:51 AM
Naming and Renaming Your Boat Sue & Larry Buying a Boat Articles 0 12-15-2003 08:00 PM
Preseason Preparation for Race Boats Dean Brenner Racing Articles 0 04-11-2001 09:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 09:00 PM
