What makes a good light air boat? - Page 3 - SailNet Community
 1Likes
post #21 of 33 Old 10-09-2009
I have also used this one to compare various boats, which might also help answer your original question. I think its been posted here before but scroll down to use the calculator. More info than you probably care to know. Have fun.
Sail Calculator Pro v3.53 - 2000+ boats
Brucerobs2 is offline
post #22 of 33 Old 10-09-2009
Originally Posted by AndrewMac View Post
Thanks for all the responses. Very helpful. Bubb2, while i know you were being a little tongue in cheek with your initial response, it was actually quite helpful. I find that I frequently get impatient in lighter air and do not let each adjustment take hold as you suggest. And JeffH's comment about the high drag a large genoa creates in the slot is not something I had previously been attuned to - always assumed that, in fact, bigger was better in those conditions. Jeff/Bubb2, I'm assuming that you mean winds that are 5 and below? I guess I'm asking at what point do you think the incremental lift of the genoa becomes accretive (ie greater than the incremental drag)? I'm sure there is no hard and fast answer, but wondering if there are metrics you would use as a general guide...thanks!
IN 5 or less a large genoa will curl. Looking more like a spinnaker than a head sail. You are trying to get as much airflow across the back side of the main as you can with the headsail. A headsail with curled leach, that is not going to happen. If you use a smaller head sail not as much curl will occur and thereby the slot opens up.
I not going to get into boat numbers because a well sailed slow boat will beat a poorly sailed fast boat every day.
Never Forgotten
bubb2 is offline
post #23 of 33 Old 10-09-2009 Thread Starter
bubb2 - thanks for the input. Reading the different comments here, it seems that, if one were in 3 knots of wind with a 130 headsail on roller furling and noticed that the leech was curling, it may well make sense to take in some of the head sail in order to reduce drag in the slot and create better airflow across the back of the main.
Btw - I hope you don't misunderstand my questions to mean that I think a different boat will compensate for the (rather considerable) holes in my sailing skills! I am very much hoping to build those skills in order to have more fun in whatever I boat I find myself in.
Thanks again!
Andrew
reading some of the comments along
AndrewMac is offline
post #24 of 33 Old 10-09-2009
Thanks again!
Andrew
Andrew, I run a 110% jib on my boat. It does well in light air and does well in heavy air. It will out point a larger sail. For the in between days is what a Asymmetrical is for.
I am not trying to say boat numbers are not important. However, what you might give in light air performance may give you stability when it gets snotty.
Never Forgotten
bubb2 is offline
post #25 of 33 Old 10-10-2009
Aeolus II
mccary's Avatar
The answer is simple: The skipper & crew! Some boats seem to spring forward while other identical hulls appear to be anchored. Of course a clean bottom and a modern fin keel and loads of sail will all help.
Joe McCary,
Sailing on The Central Chesapeake Bay, West River, MD on my Catalina 27, Aelous II with my wife and friends.
Sailing Blog:
mccary is offline
post #26 of 33 Old 10-13-2009
DrB
One more boat that does well in Light Air
To the OP,
I know that you said that you didn't want to go over 32", but with a bunch of kids and wanting to do the occasional weekender, you will need the room.
Look at a Pearson 10M (33'). On paper it looks like a slow, fat boat. It's 33' long, has a 11' beam, displaces almost 12,500 lbs, skeg rudder, but...... the thing is pretty quick. If you get the tall rig (can find one) your NE-PHRF is around 135 AND you can get it for under $25K. The standard rig is 140ish as a PHRF. It's got pretty good creature comforts and is roomy below.
Yes, you can find a quicker boat in this length range, but all aorund it won't have everything the 10M has for the price.
Disclaimer - I own one (Tall Rig) and routinely kick ass on boats much larger than ours. I crew on J105, and while it is faster than the P10M in light air, it is spartan below, very low head room and tight even though it is 2 ft longer and the same beam. I imagine the J32 will be similar.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #27 of 33 Old 10-13-2009
Send a message via MSN to LyleRussell
Getting the crew weight to leeward hasn't been mentioned as a technique on any boat.
I like a J/30 for your purposes. They have lots of room ,bunks for 5 adults and the rig is easily handled. You can get a good one for less than 25k and have money left over for fresh sails and a DIY bottom job.
LyleRussell is offline
post #28 of 33 Old 10-13-2009
Once you start seeing numbers approaching 17 and above you are getting into a more performance oriented design
My Stiletto has a sail area to displacement (SA/D) of 48.86! If I fly the spinnaker it soars to 112.2!!!
How's that for a wild ride!
Don't ignore the power of the dark side
SiXeVeN is offline
post #29 of 33 Old 05-30-2016
Re: What makes a good light air boat?
Pardon the thread bump; I don't like starting a new thread if I can recycle. I'm looking for an ultralight displacement boat for lake use where the wind is very light most of the time. If money fell from trees, I'd like a vintage model like an Express 27, Capri 30, or Olson 30. Those boats tend to cost 15K to 20K for the best, cleanest examples with lots of recent restoration work and a good sail inventory. I'd like something a bit cheaper, for day sailing only, and for no more than 4 people. Cruising acommodations are not important. I'd be keeping it in a slip, so ease of setup is not a major factor. I recently sailed on a Capri 30 in very light air and was very impressed by it's speed. We had a very experienced skipper though, which I'm sure helped. Any ideas of possible vintage ULDB designs of 24 to 28 feet or so? Perhaps other boats not officially ULDB but that still move well in light air? Multihulls are not very practical in my location due to a lack of wide slips where I would be keeping it. It would be nice if the boat was good for single handing, but I would have 2 plus guys most of the time. Any thoughts or input would be appreciated.
funcrew is offline
post #30 of 33 Old 05-30-2016
Okay first most important is skipper hands down to get the boat to go.
I just briefly read this noticed j/30 and j/32 mentioned and seeing I owned a 30 for like 20 years and have had a 32 for 15 I'll give you all my thoughts.
J/30 you had 3 head sails the biggest a 168% you could sail at around 3 knots into the wind with a 4knot breeze I know nothing about drag and was never passed with someone with a 110%.
The 32 I haven't found the right sail combo yet the first head sail was to small went to a bigger sail and wasn't happy with either light or big air.
I've been researching sails all winter because I need a whole new set. Right now what I think I'm going to do is get a code 0 figure out how high a wind I can sail it and then figure out how big a jib I can get away with.
Down wind I'm thinking code 0 and a a3.
We'll see....
rckfd is offline
Re-naming the boat pirateofcapeann General Discussion (sailing related) 130 01-07-2014 11:14 AM
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
Understanding the Racing Rules, Part Three Dean Brenner Racing Articles 0 09-09-2002 08:00 PM
